Old 08-03-2011, 01:35 PM   #1
YankeeFan123's Avatar
Trader Rating: 30 (100%+)
Default Tamiya m03 help
Hello everyone,
I have recently purchased the RTR version and by my readings I have gotten the wheel bearings and I got oil filled shocks. I raced it yesterday and all that it kept doing was traction rolling. What should I do to make it stop traction rolling and what other upgrades are recommended to make this car better. Thanks for the help in advance
Brenden Edwards
B5M| T5M
YankeeFan123 is offline   Reply With Quote
Old 08-03-2011, 01:49 PM   #2
sosidge's Avatar
There is a long thread called "Tamiya Mini Cooper" which is a great reference.
Brief answer... Tyres and shock settings.
Oil shocks - should be fitted with short Tamiya springs and set to have a tiny amount of droop (if you lift the car up, the tyres should stay on the ground for 1mm or so before lifting off the ground). With kit shock lengths that would be a ride height of just arms level or just below.
Tyres - quick fix is superglue on the sidewalls of the fronts to take the unwanted bite away. Or try some different ones that better suit the track.
Old 08-03-2011, 05:56 PM   #3
Limiting droop
Stiffer springs/oil
Tires
And most important, throttle control. With an M0-3 you need to watch the entry speed on corners or you roll over. That's the nature of the beast. Drivers with good trigger control make the car look fast in the turns but ham fist it and it's traction roll.
AreCee is offline   Reply With Quote
Old 08-03-2011, 06:16 PM   #4
pretty much the only site you need for info on minis.
http://www.rc-mini.net/joomla/index.php
read up on the M03 section and "mini for dummies". tells you pretty much everything.
Lost in RC limbo
inpuressa is offline   Reply With Quote
Old 08-03-2011, 11:08 PM   #5
Originally Posted by YankeeFan123 View Post
Hello everyone,
If you're running the Mini races at WCR, talk to Bensi Lopez cause he has his car pretty much dialed. WCR is trying to figure out the right tire combinations first, then ger the springs and shocks right second. If memory serves me correctly, it was Sweep 40s all around, 40wt oil and 3hole pistons . BL is a smooth driver and could just be making his set up work.
Granpa is offline   Reply With Quote
Old 08-04-2011, 01:31 AM   #6
Hello everyone,
a more experienced racer told me that when you are having traction rolling problems and you don't have something that you can change at the moment you just need to not take the turn as fast and as aggressively but other than that listen to granpa's advice!
platypus_s13 is offline   Reply With Quote
Old 08-04-2011, 09:39 AM   #7
Thank you Granpa. I do race at WCRC and this past Tuesday it was my first time driving and racing my Mini. I talked to Bensi and he helped me a lot and was very kind and helpful. Il try changing all of that and then I'l work on my driving.
Thank you all for all of your help.
Brenden Edwards
B5M| T5M
Old 08-04-2011, 11:32 AM   #8
Timbulb's Avatar
CA glue trick time!
Timbulb is offline   Reply With Quote
Old 08-04-2011, 11:53 AM   #9
Originally Posted by Timbulb View Post
CA glue trick time!
Doesn't help too much with mini tires. They're not foams.
Old 08-04-2011, 12:18 PM   #10
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Works for rubber tires much the same. Saved me at Snowbirds in 17.5TC.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 08-04-2011, 04:27 PM   #11
So just the outsides of the front tires or the rear tires also?
Brenden Edwards
B5M| T5M
Old 08-04-2011, 05:04 PM   #12
Nemo racing's Avatar
Send a message via Yahoo to Nemo racing
just the outside of the front tire
A800
Scorpion Power System
Nemo racing is offline   Reply With Quote
Old 08-04-2011, 05:12 PM   #13
Thanks!
Any other help anyone else can offer? I checked out that website and it helped a lot.
Brenden Edwards
B5M| T5M
Old 08-05-2011, 04:38 PM   #14
Is it the whole side of the tire or just where the rim and tire meet.
Any other help?
Brenden Edwards
B5M| T5M
Tamiya 959 - help getting it back on the road Tron Electric On-Road 9 12-29-2010 09:43 AM
