Old 08-02-2011, 07:11 AM   #1
Default mamba max pro cms36 7700kv problem
i just installed my mamba max pro esc and 7700kv motor with Turnigy 2s 30c 5000mah and 35/72 gearing , played with it for a good 5mins after that the motor starting making some weird like a screech
something like this
http://www.youtube.com/watch?v=v7DeoYVc98Y
sounds at 0:10
any ideas what to do?
nitroharry91 is offline   Reply With Quote
Old 08-02-2011, 08:10 PM   #2
What kind of car was it in ? That gear ratio of 2.05 scares me unless it was in something with steep gear reduction.
Steve. is offline   Reply With Quote
Old 08-04-2011, 03:39 AM   #3
it was in a tc4
Old 08-04-2011, 04:36 AM   #4
nexxus's Avatar
Trader Rating: 302 (100%+)
Way overgeared and over heated and a bearing has suffered. Then running it with no load is only going to make it worse. Basically you cooked the motor.
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 08-05-2011, 12:14 AM   #5
any way to fix it? or the only way to fix it is send it back to castle?
Old 08-05-2011, 05:34 AM   #6
nexxus's Avatar
At the least it'd need a new rotor and new bearings.
I don't think castle will warranty user error.
Old 08-05-2011, 09:55 AM   #7
Born2Run's Avatar
Castle sreations does not repair motors.They replace them.A few months ago you had to pay for that 35-40$.Now you have to pay 70$ and i don't know if it worths.
Whatever
Born2Run is offline   Reply With Quote
