Old 08-01-2011, 03:26 PM   #16
gashuffer's Avatar
Trader Rating: 48 (100%+)
More options included in the kit(Aluminum bulk heads etc). I think different pulleys and belts too.
T-Sal
gashuffer is offline   Reply With Quote
Old 08-01-2011, 10:10 PM   #17
Now you will change your mind about using vdf for touring?
Originally Posted by gashuffer View Post
Like stated above Hara won the Ride Cup with this car.
TubOLard is offline   Reply With Quote
Old 08-01-2011, 11:01 PM   #18
gashuffer's Avatar
Me personally? No. Why? Because Hara won a race with a midship car!! Please dude he's a world champion. He would of won that race with a tweeked ta-05 plastic car.
T-Sal
Old 08-02-2011, 08:21 AM   #19
UK.hardcore's Avatar
Midship chassis designs and conversions have been out for some time now. Here is Tamiya's Vertical Deck Frame.
http://www.redrc.net/2010/05/tamiya-...drift-machine/
Yokomo also has a DRB. These two chassis with the new TC-FD sums up the high end kits available.
You seem to forget the originator. Alex Racing's CER.
A racecar is only as good as the mechanic who build it.
UK.hardcore is offline   Reply With Quote
Old 08-02-2011, 08:43 AM   #20
gashuffer's Avatar
And the AR CER.
^5
T-Sal
Old 08-07-2011, 01:54 PM   #21
gashuffer's Avatar
Got a chance to look at the car up close. The steering rack is really a poor design for drifting. Very short and narrow.
T-Sal
Old 08-07-2011, 02:19 PM   #22
Send a message via ICQ to JiuHaWong
The steering rack is really a bad design for drifting. Very short and narrow. I was considering buying one but not now.
Can you explain?
JiuHaWong is offline   Reply With Quote
Old 08-07-2011, 03:55 PM   #23
gashuffer's Avatar
Originally Posted by JiuHaWong View Post
Can you explain?
The bulkhead and front upper deck is secured by the steering post. To achieve any sort of angle for CS drifting you will need to separate them further out, but that's not even possible because there is no room. The drag link is tiny. There is ackerman within the stock set up. For 50/50 the stock set up will work, but for CS you would need to mod it for more angle.
Don't get me wrong it's really a nice car but, the kit does not come with the CS pulley kits. That's a bummer.
For the money get a VDF.
It's no TC-D
T-Sal
Old 08-07-2011, 04:02 PM   #24
Airwave's Avatar
Originally Posted by stitchy View Post
$419.99 at Speedtech. One left!
Got it!
Hope it will be shipped soon!
Airwave is offline   Reply With Quote
Old 08-07-2011, 05:08 PM   #25
Chiefy 707's Avatar
Because believe it or not drifting is a huge sub culture of rc, especially in the Orient. It's popular here too, but not taken serious by most rc enthusiasts.
I used to be one of those Drifting is definitely a legitimate facet of R/C. I used to be a racer but now that I'm a drifter I feel like such a noob asking if I can race my Hornet in 2WD mod. People need to learn drifting is way beyond putting PVC pipe on your 4WD TC nowadays.
Hara did that?! I wonder if Rheinhard can do that with the VDS!
"It looks like a [insert car here]. It's just another [insert car here] clone!"
"Why did [insert manufacturer here] go with such a radical design? [insert manufacturer here] needs to stick with what works!" Shhhh, please.
HB/LRP/KO Propo/Protek/Associated/Tekno
Chiefy 707 is offline   Reply With Quote
Old 08-08-2011, 07:36 AM   #26
It's no TC-D
i know exactly how you feel
http://driftmission.com/the-garage/h...t-bodies-tc-d/
AzN 2NR is offline   Reply With Quote
Old 08-11-2011, 06:22 AM   #27
Chrissy C's Avatar
Car looks good.
Have HB lowered the layhaft on the FD a little lower than the TC-D and using a tensioner to eflect the belt over the motor - it looks like they have...
Anyone found a manual online they can link to or a shop that does parts yet?
Cheers
Chris
Chrissy C is offline   Reply With Quote
Old 08-11-2011, 09:17 AM   #28
gashuffer's Avatar
Originally Posted by Chrissy C View Post
Car looks good.
Cheers
Chris
With the tensioner the belt has a lot of clearance over the motor now to accept larger pulley's. The car pretty much uses all the TCX parts, apart from the obvious.
The options i.e pulley kits, spindles are not released yet.
T-Sal
Old 08-22-2011, 03:44 PM   #29
stitchy's Avatar
2 kits in stock now
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 08-24-2011, 09:00 PM   #30
transplantlife's Avatar
Trader Rating: 43 (98%+)
any updates on this kit?
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
What's new at Tai Sing Joehwee Singapore R/C Racers 168 12-07-2016 05:51 AM
