Old 07-30-2011, 07:59 PM   #1
Default Speed Passion brushless esc fan failure :(
Hi a while back the esc cooling fan burnt out on my Speed Passion Drift Master combo. I noticed the fan was spinning very quick before the failure. Would running this setup on NICAD or NIMH over power the fan and make it burn out?
86drive is offline   Reply With Quote
Old 07-30-2011, 08:17 PM   #2
Trader Rating: 48 (93%+)
nicad or nimh it should be fine if u where using a 3s lipo then yes it would cause it to burn out..
tcb22185 is offline   Reply With Quote
Old 07-30-2011, 09:27 PM   #3
Was using a couple of cheap stick packs, Definitely no li-po... Is it Probable either of the stick packs were less than 4 cell causing the failure?
Old 07-30-2011, 09:38 PM   #4
CR0SS's Avatar
Did it burn up or just stop working?
You know the guy that beat you at the last race? It was not because of his car, or motor, or battery, it is because he was a better driver. Now go practice so you can beat him.
Visit my Youtube channel for HD R/C videos. http://www.youtube.com/user/DHCross1
CR0SS is offline   Reply With Quote
Old 07-30-2011, 10:13 PM   #5
Stopped working. I'm guessing burnt out as it when it was working it was spinning rather fast.
Now hard to turn with fingers, Not freely like when new.
Also was fairly new when this happened so didn't wear out due to old age.
Old 07-30-2011, 10:33 PM   #6
CR0SS's Avatar
These fans stop working all the time. It might just be dirty see if you can get into it clean and lube it. But do not expect to work for long if you do clean it and it starts working again. These type of fans always are a pain whether they are in a RC car or computer.
Old 07-31-2011, 06:57 AM   #7
It never really had a chance to get dirty. That's how little I used it..
Plus according to the sales pitch these are meant to be "dust proof"
Old 07-31-2011, 12:03 PM   #8
koopesv's Avatar
Trader Rating: 18 (95%+)
I never use a fan with Speed Passion esc and never had a problem with Temps.
Durango - Speed Passion - Trinity
Gforce Hobbies Raceway
Urban Heat Racing
koopesv is offline   Reply With Quote
