Old 07-29-2011, 09:51 AM   #1
FaanP's Avatar
Default Help needed with 1/12th scale roll-out
Hi,
I'm pretty new to 1/12 scale and need some help. I'm planning to run a 4.5 - 5.5 turn motor in a crc chassis. We have 2 local tracks 1 outdoor which is pretty long and quick while the indoor track is short and tight. What kind of roll-out numbers must I aim for on the 2 different tracks? I have no clue.
When in doubt - GAS IT!!
FaanP is offline   Reply With Quote
Old 07-29-2011, 10:04 AM   #2
Chaz955i's Avatar
Originally Posted by FaanP View Post
Hi,
Have you spoken to some of the drivers you will be racing against at these tracks? Hopefully they will share what they are running or at least get you in the ballpark. This would probably be the best bet as a long track to one person may be short to another which might result in some not overly helpful advice.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 07-29-2011, 11:47 AM   #3
FaanP's Avatar
Now that is part of the problem. We are a couple of guys that is trying to get the 12th scale going since nowbody runs them. Thus we are starting with no info, and nobody to help
Old 07-29-2011, 01:13 PM   #4
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Check the CRC setups page for rollout and setup info...
http://www.teamcrc.com/crc/modules.p...showpage&pid=7
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 07-29-2011, 11:07 PM   #5
I run 3.5T so it will be much lower..... but for large outdoor track I run around 35mm vs short track around 30mm..... so maybe a big higher like 35-40mm?
http://www.gpm-parts.com
gpm-parts.com is offline   Reply With Quote
Old 07-29-2011, 11:38 PM   #6
FaanP's Avatar
Thnaks all - the setup sheet up sheets I looked at didn't have any gearing but 35 - 40mm will give me a starting point ...
Old 07-30-2011, 06:03 AM   #7
Hi,
You need to look up the thread relevant to your ESC and ask the same question there. You will get much better help there.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 07-30-2011, 11:05 AM   #8
FaanP's Avatar
Tx
1/12 forum ovalnator Electric On-Road 46184 Yesterday 09:37 AM
BMI's DB12R Mr. Shookie Electric On-Road 8730 02-11-2017 12:12 PM
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 09:27 AM
Horsham Rc Carpet racing 2009 Jeff Cuffs Racing Forum 3890 09-12-2010 02:01 PM
