Old 10-26-2004, 10:16 AM   #1
imjonah's Avatar
Default Parking Lot practice
The problem with just finding an empty parking lot and using it to practice seems to be poor traction.
(My XXX-S belts are sealed off so pebbles and small rocks are less of a problem)
Any advice on setting up the car to run on an unprepared parking lot. Would it make sence to run foams to get better traction or would the parking lot chew them up. What about treaded tires?
[I do not have a leaf blower and I would like to avoid getting one if possible]
imjonah is offline   Reply With Quote
Old 10-26-2004, 10:31 AM   #2
raving-monkey's Avatar
Send a message via MSN to raving-monkey
i wouldn't use foams ina car park at all because all the dust just fills in the pours (sp) on the foam so you would get no grip at all...but best would to go for some treaded rubber tyre..maybe a wet tyre as it might be better getting rid of all the dust etc from under the tyre if you get what i mean.
raving-monkey is offline   Reply With Quote
Old 10-26-2004, 10:31 AM   #3
kufman's Avatar
I would run something like HPI Advans since they are treaded and rubber. Foams get chewed up pretty fast on surfaces other than carpet. Once you learn to drive well on rubber, foams will seem easy.
Brushes? We don't need no stinking brushes!!!
kufman is offline   Reply With Quote
Old 10-26-2004, 01:46 PM   #4
Chill Will's Avatar
Find a tennis court to practice on. It will be smooth and cleaner.
Chill Will is offline   Reply With Quote
Old 10-26-2004, 02:05 PM   #5
Good idea but, what happens when you go back to the ashfalt?
Tony Szep is offline   Reply With Quote
Old 10-26-2004, 02:15 PM   #6
rayhuang's Avatar
Wont matter one bit-no set-up that workson unprepared surface will work wellon a prepared racing surface-like asphalt with traction compound or carpet.
One suggestion-make sure no fast corners you lay out happen in an off-camber corner. With no grip and weight transfer-your car will spin everytime and no set-up change willl help.
Ray
Old 10-26-2004, 02:15 PM   #7
Speedie's Avatar
Most tennis courts are asphalt
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 10-26-2004, 04:24 PM   #8
Chill Will's Avatar
We race on a tennis court. We have good traction on it with foams and rubber tires. We even race modified.
Old 10-27-2004, 01:02 PM   #9
Oh, really thats cool
Old 10-27-2004, 10:27 PM   #10
edseb's Avatar
You can get an electric leaf blower for pretty cheap and run it off the power in your pits. Run rubber like Take Off 27s or Sorex 36s. Just run a little more roll and even try to spray the asphault with soda water to help if you have the time.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 10-28-2004, 02:36 AM   #11
tornado
Guest
Posts: n/a
Originally posted by edseb
........... even try to spray the asphault with soda water to help if you have the time.
We use coke
Bryan
Old 10-28-2004, 11:52 AM   #12
Hebiki's Avatar
Trader Rating: 26 (100%+)
actually being a former tennis instruction here in so cal the tennis courts here would be ideal for rc cars. they are sprayed with a very fine material that gives them that light abrasive feel. it would be PERFECT for traction as soon as you blow off the dust. the only problem would be.. there are the two poles for the net. and tennis courts arent that big.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 10-28-2004, 12:09 PM   #13
Super Moderator
Trader Rating: 17 (100%+)
blow off or sweep off the surface the best you can then get some double purple fronts and purple rears, put on some paragon and run.
Tekno|JConcepts|TeamTrinity|BOOMrc
Bob Barry is online now   Reply With Quote
Old 10-28-2004, 04:21 PM   #14
Chill Will's Avatar
On the rear, I wouldn't run anything softer than purples on the tennis court. It can be kinda hard on them but great traction.
Old 10-30-2004, 09:16 PM   #15
Nrctc3's Avatar
Send a message via AIM to Nrctc3 Send a message via Yahoo to Nrctc3
Well, for a parking lot practice. I'd first bump-up the right heigh 1/2mm or maybe a whole 1mm. Just so you dont bottom out & scrape up your chassis on the uneven pavement.
Nrctc3 is offline   Reply With Quote
parking lot racers party_wagon Electric On-Road 13 08-07-2008 02:58 PM
R40 Parking Lot Setup? RS4-R40 Nitro On-Road 10 03-06-2006 05:32 PM
Practice rubber tires, practice 3000 batts, Novak smart tray, Orion Lap counter grazianos R/C Items: Wanted to Buy 2 03-26-2005 04:22 AM
Parking lot practice vs racing RE:traction imjonah Electric On-Road 12 04-25-2004 11:04 AM
Parking lot fun tpunx99GSX Minnesota and North/South Dakota Racing 3 08-05-2003 11:06 PM
