Old 10-12-2011, 06:09 AM   #106
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Originally Posted by hacker View Post
so whats the story with the +4mm shock towers?
why, when?
I have not been following, have not even driven mine yet. Still waiting for some parts to replace some missing kit parts.
4mm towers to be able to run full length shocks such as TRF shocks
Alex Ilievski
*INFINITY * R1 WURKS * PLAIG BEARINGS* SPEEDY RC
A Ilievski is offline   Reply With Quote
Old 10-12-2011, 01:49 PM   #107
Trader Rating: 20 (100%+)
What is the advantage of running puddy in your gear diff instead of oil?
TLR 22 3.0
TLR 22-4
Cooper Motorsports
R.Fenstermacher is offline   Reply With Quote
Old 10-13-2011, 02:28 AM   #108
barts71m's Avatar
Trader Rating: 34 (100%+)
why, when?
Gives u the chance to also run a more common spring set. Also had some ride height issues with the original springs. Car feels a bunch more stable on the TRFs.
Smokem Racing, KBI Factory Team, Need some speed get some EAD, Contra Industries
barts71m is offline   Reply With Quote
Old 10-13-2011, 02:58 AM   #109
Pro10noob's Avatar
You can also use the TRF416 shock tower at the rear.
With this shock tower you can use the white Tamiya springs and you only need the plus 4 front shock tower.
Funny thing was with my Sakura Zero that i didn't even use the 4mm up shocktower at the front and still run Tamiya springs
All this was with the stock shocks and the -1 springplatform.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 10-13-2011, 06:29 AM   #110
barts71m's Avatar
Exclamation
The 3 racing towers are about half the price and have more adjustment
Have some spare Tamiya towers that I looked at putting on first.
Old 10-13-2011, 06:34 AM   #111
Pro10noob's Avatar
You could also use the Team Magic springs.
No need for adjustments
regards Roy
l===/o\===l
Old 10-13-2011, 06:41 AM   #112
barts71m's Avatar
For those interested - +4 Towers
http://os.3racing.hk/products.php?products_key=5347
http://os.3racing.hk/products.php?products_key=5349
Old 10-13-2011, 09:59 AM   #113
what would be better if using +4 towers and tamiya shocks?
better handling?
very pleased with my car now, but is there is always room for improvement
also, is the tamiya trf damper cylinders availible seperately or do i have to buy a complete set of shocks?
Team Associated TC7.1 - Hobbywing - Highest - Sanwa - Gens Ace
Team Associated B5R - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 10-13-2011, 04:48 PM   #114
A Ilievski's Avatar
better handling?
To run the TRF shocks with the 4mm towers you will need the TRF cylinder along with the shock shafts as they are longer than the 3R ones. Then you can just put the 3R shock caps on it. They do sell these parts separately but might be easier just to buy a set of TRFs.
Alex Ilievski
Old 10-14-2011, 12:03 AM   #115
ian scott's Avatar
Trader Rating: 14 (100%+)
ran the x1 last night handle well on low grip cement.
Question for you lot what is the best way to hold the battery in(lipo 2s)
The sakura zero s had the battery strap but the narrow chassis you cant use it any suggestions
Xray t3 2011 tourer with 13.5 speed passion, xray t4 2013 tourer fw-06 nitro tourer .t maxx converted to emaxx 6x6
losi 22buggy losi 22t
serpent 1/8 811 ep, tamiya mo5 mini
ian scott is offline   Reply With Quote
Old 10-14-2011, 09:38 PM   #116
Running putty or high visc oil is for simulating the spool axle for corner exit on power steering grip (less compared to a spool) but slightly better turn in compared to a spool and less wear on drivetrain.
Tastetickles is offline   Reply With Quote
Old 10-14-2011, 09:40 PM   #117
Most use filament tape, I use double sided velcro to secure velcro'd lipos to the chassis.
Old 10-14-2011, 11:32 PM   #118
ian scott's Avatar
thanks tastetickles did that on the zero but with the x1 chassis being narrow it not holding much
Old 10-15-2011, 08:45 AM   #119
Yeah that's why i put the velcro (rough side) on the battery top side as well, the hairy side to go over that and then another layer of the strap itself to go over that. Haven't encounter any problems of battery flying even after car flew 2 feet up in air and some side impact from other cars.
Old 10-15-2011, 08:51 AM   #120
I have a question for those that had tried the recommended setup in the manual. I'm assuming that the spool setup would have more understeer but how come the recommended setup still went with a stiffer front spring and stiffer stabilizer bar?
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 05:14 PM
About Sakura Zero AlexNg Malaysian R/C Racers 290 07-17-2012 07:51 AM
