Old 10-08-2011, 08:36 AM   #91
JustWill75's Avatar
Send a message via AIM to JustWill75
Is anyone running one of these at the IIC in Vegas? I wonder how it does at a event like this?
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 10-08-2011, 10:04 AM   #92
tested the car for the first time today, very neutral handling, easy to drive!
very pleased with the car! tested on carpet
only downside is the plastic in the suspension, broke a c hub and a knuckle arm after a quite mild crash, i would like to see some better material in the suspension! (havent broken any suspension parts in years before today)
Team Associated TC7.1 - Hobbywing - Highest - Sanwa - Gens Ace
Team Associated B5R - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 10-08-2011, 10:14 AM   #93
Madulla's Avatar
Haven't seen the XI yet, but on the Zero I needed to upgrade to a hard XRay bumper to protect the front bits. Stock foam was way to spongy and would crumple right to the wheels. I would break something almost every heat.
Hobbywing North America Team Driver
hobbywingdirect.com
Madulla is offline   Reply With Quote
Old 10-08-2011, 04:50 PM   #94
Default Sakura XI
Anyone know where is the state sakura XI with a lower price?
Carlos Zaranza
TC6 / Tekin RS / LRP 9.5t / Spektrum Dx3s
Sakura Zero S CS 1.7 /Turnigy 60a + 10t / Hk310
Slash 4x4 / Velineon system
www.carloszaranza.com
zaranza is offline   Reply With Quote
Old 10-09-2011, 09:33 AM   #95
Default Big Thumbs Up
Had the car for 3 weeks now and running it everyday. Here's what I have to share:
Pros:
1. Good quality and fitment overall.
2. Weight distribution is amazing, loaded with everything all 4 sides weight is within 10 grams. (haven't played with weights yet)
3. Great rear traction
Issues encountered:
1. Slight slob in steering system makes getting front toe precise more time consuming despite using the steering lock.
2. Servo saver/horn doesn't center properly due to the gap in horns and springs (easily solved by replacing it with servo saver system from another brand)
3. Front sponge bumper is useless after taking a few hits, it retains its shape but its not as tough anymore
4. Pins coming loose from universals
Currently running stock setup with following:
1. Front gear diff with 3racing AW grease
2. Softest front stabilizer bar from 3racing
3. Front spring changes to 5.75T from 3racing
4. Xerun 5.5t motor (mod firmware max boost at 8.75 fdr)
Slight understeer on corner entry as expected from differential and slight understeer on power mid corner. The latter should go away with a front spool or recommended 500k oil in diff. The car is extremely easy to drive atm, will be testing with front one way next week.
Tastetickles is offline   Reply With Quote
Old 10-09-2011, 12:59 PM   #96
yeah the servo saver is crap.
on carpet i ended up using the box setup, only changed the rear springs to 5.25, just to get less rear traction.
going to try gear diff in front next time
Old 10-09-2011, 02:05 PM   #97
Trader Rating: 20 (100%+)
Not 100% sure what your asking but if its about price RCMarket.com has the cheapest price I saw.
I also have a question, are the spur gears the same on the XI and the Zero?
TLR 22 3.0
TLR 22-4
Cooper Motorsports
R.Fenstermacher is offline   Reply With Quote
Old 10-09-2011, 02:14 PM   #98
i think they are the same
how is the quality on the 3racing spur gears?
i switched to a kimbrough spur when i built the car, but need to order som more sizes, and white gears look soo much nicer
Old 10-09-2011, 10:49 PM   #99
wollow86's Avatar
Is anything else required for mounting the T3 bumper? I'm going to start collecting the bits I need for the kit. I'll add servo saver to the list, any suggestions on brand? I'm already using a kimbrough one on my f109.
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 10-10-2011, 07:35 PM   #100
The 3racing spurs are tough enough for a dirty asphalt track, I actually destroyed the aluminum pinions from 3racing and kawada and the spur is still ok. I wouldn't bother using the white spur though coz they don't look nice anymore when dirty. I switched to Tamiya 0.4 module gear setup for wider range of gear ratios and mainly the steel pinions.
Old 10-10-2011, 07:50 PM   #101
Does anyone know if the ops Sakura zero body mounts are the same as the xi ones meaning can I use the same body's
Lizardboy76 is offline   Reply With Quote
Old 10-10-2011, 11:08 PM   #102
ian scott's Avatar
Trader Rating: 14 (100%+)
Talking
Lizardboy yes the body from sakura zero will fit all you have to is put the rear body post on theback of the shock tower
Xray t3 2011 tourer with 13.5 speed passion, xray t4 2013 tourer fw-06 nitro tourer .t maxx converted to emaxx 6x6
losi 22buggy losi 22t
serpent 1/8 811 ep, tamiya mo5 mini
ian scott is offline   Reply With Quote
Old 10-10-2011, 11:10 PM   #103
ian scott's Avatar
Default spur gear
Yes the spur gear from the zero will fit the x1
Old 10-12-2011, 03:55 AM   #104
barts71m's Avatar
Trader Rating: 34 (100%+)
Ran my car last night in 17.5 boosted with the +4 shock towers and TRF shocks on it and HPI springs, car is even better and improved both lap time and 5 minute time. Loving this car. Having a little issue getting some steering into it though. Hoping change of spring and bodyshell might improve it.
Smokem Racing, KBI Factory Team, Need some speed get some EAD, Contra Industries
barts71m is offline   Reply With Quote
Old 10-12-2011, 05:05 AM   #105
hacker's Avatar
Trader Rating: 141 (100%+)
so whats the story with the +4mm shock towers?
why, when?
I have not been following, have not even driven mine yet. Still waiting for some parts to replace some missing kit parts.
hacker is offline   Reply With Quote
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 05:14 PM
About Sakura Zero AlexNg Malaysian R/C Racers 290 07-17-2012 07:51 AM
