Old 08-22-2011, 08:20 AM   #31
Born2Run's Avatar
Great info Kid TT-01.Thanks
Whatever
Born2Run is offline   Reply With Quote
Old 08-22-2011, 10:18 AM   #32
still no news on sakura zero xi facebook lucky draw?? marketing gimmick???
hansenhon is offline   Reply With Quote
Old 08-22-2011, 11:22 AM   #33
dameetz's Avatar
They announced it 2 days ago.....a guy from Singapore won it.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 08-22-2011, 02:28 PM   #34
what springs does the XI come with?
and what springs do i need to have in my box? will be running the car indoor on carpet (have a set of tamiya springs here but always nice to have original equippment )
guessing that 4-500 oil would be a good start in the shocks?
Team Associated TC7.1 - Hobbywing - Highest - Sanwa - Gens Ace
Team Associated B5R - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 08-24-2011, 07:26 PM   #35
Tested my Sakura XI last night and really happy with it. Easy to drive!
Anyone know when the optional shock towers (4mm plus) will be released? I can only use 3racing springs with the stock towers at the moment.
Thanks!
yokfans is offline   Reply With Quote
Old 08-24-2011, 09:26 PM   #36
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Thanks!
Run some TRF shock bodies with the shock shafts . But then if you need the extra clearence you could always use the 416/417 rear shock tower IF it lines up.
Alex Ilievski
*INFINITY * R1 WURKS * PLAIG BEARINGS* SPEEDY RC
A Ilievski is offline   Reply With Quote
Old 08-24-2011, 10:49 PM   #37
Pro10noob's Avatar
You can use the Team Magic springs without any problems.
I did on my Sakura before i got the 4mm up shock towers.
I believe the Tamiya white springs should also work.
See pic's below.
Both where without the 4mm up shock towers
Regards Roy
Thanks!
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 08-25-2011, 12:39 AM   #38
Seems that you are using trf416 shock tower, right??
See pic's below.
Regards Roy
Old 08-25-2011, 12:57 AM   #39
Pro10noob's Avatar
Yes i am
Here in Holland i was one of the first to try this setup.
I could copy the setup from my TRF416X to the Sakura and it drove like a dream
This setup is in combination with the short rear arms but not using the narrow suspensionblocks.
The Team magic springs with fir for sure.
They are a bit shorter then the Tamiya or Sakura springs.
You can also use the -1mm spring retainer if you want some more room for the springs
regards Roy
l===/o\===l
Old 08-25-2011, 02:07 AM   #40
So in other words, both the front & rear TRF416 shock towers will fit the Sakura XI also, right?
Yes i am
regards Roy
Old 08-25-2011, 02:13 AM   #41
Pro10noob's Avatar
About the front i can't confrim this as i only used the rear TRF shock tower and the stock at the front or the 4mm up tower.
regards Roy
l===/o\===l
Old 08-25-2011, 06:38 AM   #42
=FLIP='s Avatar
Trader Rating: 24 (100%+)
Ran the car with great sucess in 17.5 boosted class 2nd place at big meeting with no previous tracktime with car built 1 day before race.
very strong and fast ,responded well to changes, stable and verry good midcorner speed all in all great car!!!!!!!!
the new 3racing + 4 mm shock towers will sort out the issue of not being able to run longer springs they have just been released .
the rear belt tensioner is also a really good addition lets you run belt looser without skipping .
and the bando belts are the best belts around good improvement over previous ones.
Well done 3 racin on a well built well thought out car
--------------------------HOBBYWING----------PROAMP LIPOS----------------------------
-EAD- Racing NEED SPEED GET SOME EAD-
=FLIP= is offline   Reply With Quote
Old 08-26-2011, 09:48 PM   #43
Yes i am
regards Roy
Hi
And Bulkhead Cover, you use Front?
Any other modification need to use this Tower from TRF?
Best Regards
Luis Mello
LuisMello is offline   Reply With Quote
Old 08-27-2011, 02:30 AM   #44
this +4mm towers you are talking about, can i use tamiya springs on my sakura xi as it comes out of the box or is the +4mm towers something i have to buy extra for the car?
havent got the car yet, hope it will arrive here next week!
Old 08-27-2011, 02:35 AM   #45
Pro10noob's Avatar
With my Zero, i used the front top bulkheads on the rear.
The TRF tower you need to widen the screw holes just a bit.
Don't over do tho
regards Roy
Originally Posted by LuisMello View Post
Hi
Best Regards
Luis Mello
l===/o\===l
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 05:14 PM
About Sakura Zero AlexNg Malaysian R/C Racers 290 07-17-2012 07:51 AM
