Old 02-23-2012, 03:55 PM   #196
wollow86's Avatar
Smallest spur is 60t. You do have to drill the holes for the spur gear holder though. That would let you get up to something like 40ish pinion.
Or a 65 is the smallest that will actually fit, no drilling.
To get more room you can use the motor mount root from a zero vertical motor mount, or dremel the XI mount. Either way will get you a few extra teeth on the pinion.
Problem solved tho when the new motor mount comes in
Thanks for the setup tips. I do like the MM32, but sorex 36 at edgie (maitland) is maybe just a bit better. It was also cheaper as a bulk price. I have a set of MM32 to run at castle hill tonight.
ride height and so forth, I run that because the track is very bumpy in places, and as it is my chassis does get scraped quite a bit. Same reason for the shock oil. Faster guys are even softer with the oil in their cars, around 30wt. The diff even with 50wt oil can be difficult on corner exit if im to aggressive. And when I first got the car my choice was 2000wt kit (I tried that first), or 50wt shock being the thickest I had. Even 3 racings diff building guide was using 40wt?
I still have a lot of things I'd like to try, springs included.
Is your droop advice a mm amount, or a gauge reading?
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 02-23-2012, 08:33 PM   #197
barts71m's Avatar
Trader Rating: 34 (100%+)
That reading is on a guage. 6/5.
Once u change droop try the ride height change. Id give the other changes a go. Different car
Smokem Racing, KBI Factory Team, Need some speed get some EAD, Contra Industries
barts71m is offline   Reply With Quote
Old 02-25-2012, 01:39 AM   #198
My car is now built and ready for its first run tomorrow on tarmac. I have used the set up in the back of the manual as a starting point.
Team Powers UK Ltd
RGT Uk
martynp is offline   Reply With Quote
Old 02-25-2012, 05:44 AM   #199
wollow86's Avatar
Let us know how you go.
Old 02-26-2012, 04:40 PM   #200
I ran my new X1 at my local track Wombwell today, as the day went on I got the car handling better from being tail happy to very stable qualified 5th in the A and finished 2nd less than a second behind. So all in all not a bad day for a first time out, the car had not even touched tarmac before the practice session which is limited and only got about 5 laps in before the first race.
First thoughts are the car is quick with a lot of potential as I get the set up more refined but being the only car in this area I know of it will take a bit of time to find the sweet spot on set up.
Team Powers UK Ltd
RGT Uk
Old 03-17-2012, 03:57 AM   #201
wollow86's Avatar
Originally Posted by wollow86 View Post
Stumbled across these on the 3Racing site today.
New suspension blocks, both FR 0 and RF 0 : SAK-X22/PK, SAK-X23/PK
Heard back from 3 Racing these are due out in April, they don't have an eta on the motor mount.
Old 03-17-2012, 04:41 AM   #202
cannon's Avatar
Trader Rating: 35 (100%+)
The new XI DH version is due out at the end of the month. Not sure if the car will have the split blocks and new motor mount
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 03-17-2012, 05:00 AM   #203
wollow86's Avatar
Any more info on the XI DH? First I've heard of it.
Old 03-17-2012, 05:11 AM   #204
cannon's Avatar
New chassis and top deck that I know of so far
Old 03-17-2012, 06:52 AM   #205
wollow86's Avatar
Perhaps for more flex? I accidentally ran my car with all the rear deck screws loosened after a pinion change. I couldn't understand why the car felt so good or why it was making a funny clicking sound when changing direction.
If I've gotta buy a new chassis, deck, suspension blocks and motor mount... I'm almost there for a new car... That suggestion didn't go down well with the wife though. lol
Old 03-17-2012, 03:34 PM   #206
ferfelu's Avatar
Default Sakura XI ver DH..
http://www.area52.cc/news/2002-3-rac...h-edition.html
Serpent S411 Eryx..
Associated RC10L2.5..
Speedzone USA www.speedzoneusa.com
From the beautiful island of CURACAO
ferfelu is offline   Reply With Quote
Old 03-17-2012, 08:43 PM   #207
wollow86's Avatar
Thanks ferfelu.
That new chassis looks interesting... I want it
Old 03-22-2012, 06:27 AM   #208
ShadowAu's Avatar
I've read this thread through and I've seen a lot of people are using this car with 17.5's etc, but how does it go with a good mod motor?
I've been keeping an eye on the XI for a while and its basically a choice between it and the AE 6.1... leaning slightly to the XI as its available locally and I can used my TRF shocks etc with it
I am quite content with doing what I do
Don't mistake not being happy for unhappiness - its not the same thing
ShadowAu is offline   Reply With Quote
Old 03-22-2012, 11:27 AM   #209
i have raced the xi all winter in 17.5 boosted and i have been struggeling with to little traction in the rear, have tested alot of different things but didnt get any good feeling/balance
changed to a tc6.1 and it has more traction all around out of the box, plus that it has TONS more of steering compared to the xi, i was faster from with the tc6.1 from the 1st pack on the track
looking at quality the carbon fibre and aluminium is slightly better on the sakura, but the plastic in the suspension parts breaks quite easlily even in mild crashes
and the xi looks cooler with the pink coloured parts
i would choose tc6.1 if i were you, you wont be sorry!
Team Associated TC7.1 - Hobbywing - Highest - Sanwa - Gens Ace
Team Associated B5R - Hobbywing - Highest - Sanwa - Gens Ace
Bappe is offline   Reply With Quote
Old 03-31-2012, 02:37 AM   #210
wollow86's Avatar
Originally Posted by barts71m View Post
Also Willow your setup is very different. Ride Height and droop are very strange. Also have been running alot harder in shock oil/diff oil 450 muchmore, and 1000wt diff oil. I would give 6/5 droop a go and 5/5.5 ride height. Try some Muchmore 32s car is weapon on them. Our track is not to different from Maitland in terms of grip levels. Springs I cant help with running +4 towers with TRFs. Couldnt make the car nice with the original gear.
Should mention that was with 17.5 boosted.
Right, just dropped ride height to 5.5 front and 6 rear, but will try dropping to 5.0 5.5 tomorrow at the track to see how it goes as well. On your advice I dropped the amount of droop now (on my gauge it reads as rear 4 front 5) to 2mm rear and 1.5mm front.
Will see how well it goes
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 05:14 PM
About Sakura Zero AlexNg Malaysian R/C Racers 290 07-17-2012 07:51 AM
