Old 11-01-2011, 02:44 PM   #136
cwoods34's Avatar
Originally Posted by seaball View Post
cody - i tested the whole set a while back ...
4.25T - 35.8 lb/in
4.5T - 31.7 lb/in
4.75T - 29.2 lb/in
5.0T - 26.2 lb/in
5.25T - 24.9 lb/in
5.50T - 22.9 lb/in
5.75T - 21.2 lb/in
6.0T - 20.0 lb/in
6.5T - 17.9 lb/in
unless they made some changes, it's a fairly usesless set on rubber. btw - i have two sets for sale should anyone disagree with me.
Eh, yeah 22.9 is a bit stiff on a TC6. Even most mod setups don't go over 16.5.... but thank you! Do they have springs softer than the 6.5/17.9? I'd be interested to pick up some.....
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 11-01-2011, 02:48 PM   #137
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
not that i know of. the xray black spring set is pretty stout and goes from around 12# to 20#.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 11-01-2011, 03:16 PM   #138
wollow86's Avatar
Will any type of spring fit the sakura shocks? Or will I need to organise a set of +4 towers and some TRFs...
Supporting Aussie hobby shops:
- www.MRJRacing.com.au - - www.feralbatteries.com.au - - www.actionrc.com.au -
wollow86 is offline   Reply With Quote
Old 11-01-2011, 03:26 PM   #139
cwoods34's Avatar
I have been using Reflex Racing springs on the Sakura shocks, and they work flawlessly..... So those, Associated, and colored XRAY springs all fit.
Old 11-01-2011, 04:17 PM   #140
wollow86's Avatar
Ok cool, thanks. I'll pick some of those up.
Old 11-02-2011, 12:48 AM   #141
Pro10noob's Avatar
I used tM and Tamiya springs without any problems on the Sakura shocks.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 11-03-2011, 09:29 AM   #142
racer x 1's Avatar
Trader Rating: 27 (100%+)
ok so Im looking to purchase this car and return to tc racing but i have a few questions like: what is the exact reason for the plus 4 shock towers and what springs are being used since the 3racing kit is in sufficient for rubber tire asphalt racing? thanks in advance
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 11-04-2011, 01:22 AM   #143
wollow86's Avatar
Most of that info is like at the top of this page... And maybe back one. Did you read any of it?
Consensus is that the Sakura springs are to hard. I havent run my XI yet ( have to wait till the birthday ), but I use 14lbs on my current car for parking lot type surface. I plan to grab assosiated green, silver and blue, 4 of each.
The +4 towers are to fit tamiya TRF dampers (and maybe others?)
Old 11-04-2011, 07:48 AM   #144
barts71m's Avatar
Trader Rating: 34 (100%+)
Pretty much I switched to the +4 towers and the -1 spring retainers so I can run the TRF shocks with the 3 racing shock caps etc. Car is weapon have been switching between pink/silver, silver/silver HPI spring combo. Car feels a little free with the silvers all around but I find it nicer to drive.
Smokem Racing, KBI Factory Team, Need some speed get some EAD, Contra Industries
barts71m is offline   Reply With Quote
Old 11-04-2011, 09:26 AM   #145
racer x 1's Avatar
ive read the thread already but it just wasnt very clear to me. between some guys saying you have to run other companies shocks to run softer springs and others saying no its not true. thank you for clearing it up.
Matt Bell
Old 11-04-2011, 01:03 PM   #146
4.25T - 35.8 lb/in
4.5T - 31.7 lb/in
4.75T - 29.2 lb/in
5.0T - 26.2 lb/in
5.25T - 24.9 lb/in
5.50T - 22.9 lb/in
5.75T - 21.2 lb/in
6.0T - 20.0 lb/in
6.5T - 17.9 lb/in
Honestly, how did you measure the springs? Your measurements would mean that a 6.0T Spring has exactly the same spring rate as an HPI Gold Spring. That is just not true. I own both and the HPI Gold spring is alot stiffer.
I do not have the capabilities to measure them but just compressing the springs on my pitboard using my finger makes it very clear that those springs are not equal. HPI Gold feels very close to the 5.25T Spring, but never equal to the 6.0T.
I tested the 6.0T and 6.5T Springs on the track and the car felt very sluggish, so they have to be pretty soft. I use to run 5.5T or 5.25T in the front and 5.75T in the back with very good results.
hermmie is offline   Reply With Quote
Old 11-04-2011, 01:49 PM   #147
seaball's Avatar
LFRA4500
while my test methods/calcutions may well have been flawed, i'm betting rather, that it's a qc issue. many manufacturers have no idea what their own springs test out at. probably why the lastest trend is simply to label the springs by wire thickness and coil spacing. that way, when their supplier sends them garbage, the end product still falls within their visual description, albeit performing nothing like other batches.
pretty much everything quantifiable in our industry is like this. yeah, i can read, and i know the bottle says "650 cSt" ... the lessen, here? don't borrow shock oil, springs, tires, etc.
Old 11-06-2011, 03:33 AM   #148
wollow86's Avatar
Has anyone tried TRF mini springs? They look very similar off the car..
Old 11-06-2011, 03:48 AM   #149
Pro10noob's Avatar
I did and they are to short.
You have to wind down the springplatform almost to the end.
TM spings are a good fit and i also used Tamiya springs on the Sakura.
This was with the -1mm lower spring retainer.
Left tamiya springs, right the TM springs.
regards Roy
l===/o\===l
Old 11-06-2011, 04:24 AM   #150
barts71m's Avatar
They would more than likely work fine with the original shock/shock retainer setup. Can test them out if you like.
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 05:14 PM
About Sakura Zero AlexNg Malaysian R/C Racers 290 07-17-2012 07:51 AM
