Transmitter batteries >
Old 10-25-2004, 06:55 PM
INFERN0's Avatar
Default Transmitter batteries
I can't find any info on upgrading transmitter batteries. I would like to drop a LiPoly 14.8 volt battery pack into my M8 with a voltage reg on it but would like to know who has already done this and what is needed to be done , what batteries etc.
Any info would be great as I am kinda in the dark on this one. I have the Triton for this reason alone and i think the LiPoly will be the ultimate battery for transmitters with no memory in them.
INFERN0 is offline
Old 10-26-2004, 12:04 AM
Speed Demon's Avatar
Default Re: Transmitter batteries
14.8 volts??? I think the M8 can take max 8 x 1.5v cells which is equal to 12 volts... But like you said, putting a regulator with it is okay I think.. but what are the size of the LiPoly battery and what's the capacity????
It's interesting if you can do it... all the best.. and keep up posting.
Speed Demon is offline
Old 10-26-2004, 12:34 AM
Mind_Blower's Avatar
I've been using a 3cell LiPo in my transmitter for year now with no problems. The cells are 4.2v each fully charged which come out to 12.6v and 8 alkaline batteries are closer to 13v in series when new. I used to run a 9cell NiCad that when charged fast it would be 13.2v right off the charger and never had a problem with that one either. You should be able to find lower voltage LiPo cells so you wouldn't need a regulator. Most LiPo's that I know of are rated at 3.6v and full charge voltage is 4.2v.
Mind_Blower is offline
Old 10-26-2004, 02:13 AM
That'a a good results .... what's the capacity??? and how do you charge them?? Is it AA size???
Old 10-26-2004, 07:24 AM
Mr. Shookie's Avatar
HT Batteries sells the whole lit For I think $95.00 including a charger but it sounds you don't need it so I think the tray and batteries it comes to $65.00 Check it out. I almost bought some but I switched to the Helios.
Here is the link
http://www.htbatteries.com/Public_html/Tx%20packs.htm
Hope this helps.
Stephen <><
Mr. Shookie is offline
Old 10-26-2004, 09:59 AM
It's a 2200mah and I get about 10 hours of use per charge. I charge it with a Hobbico Quick Field Charger MkII. The cells I used are flat and measure about 2 5/8" long, 2 1/8" wide, and 3/16" thick. That's each cell. I know it fits the R-1 and 3pk just take out the battery tray and add some foam to take up the dead space. You'll have to take a little material off the radio under where the tray sits to get the battery to sit low enough to clear the battery door.
Old 10-27-2004, 05:53 AM
INFERN0's Avatar
Hmm. The HT's look kinda neat but the capacity is somewhat lacking. I am looking for that 10 hrs of use without charge type deal. Do you have any more info on what you did ?
INFERN0 is offline
Old 10-27-2004, 12:24 PM
I got mine from here
http://www.batteriesamerica.com/lithium_polymer.htm
I made my own using the LP2200 cells but I see they have pre-made 3cell packs now that might work although they put a different plug on it. You can see in the pics of the cells at the top of the page that there is a little extra material all the way around the cell, when you build it just make sure you fold it up or it will be a struggle to get it in the radio.
