What's the best way to break in a new motor??? >
Old 10-25-2004, 05:08 PM
Default What's the best way to break in a new motor???
What's the best way to break in a new motor??? On a dyno??? water????
6Cuda6 is offline
Old 10-26-2004, 12:02 AM
COLEKO's Avatar
Default Breaking in motors
Everyone has there own way of breaking in motors. So you might here all kinds of methods...Some people dont even do it. The way I break in mine is with a slave motor using a RPM motor stand for 5 to 10 minutes at 3 volts on the slave motor.
COLEKO is offline
Old 10-26-2004, 12:12 AM
berger's Avatar
2V for 3-5 minutes.
berger is offline
Old 10-26-2004, 12:17 AM
Matt Howard's Avatar
in my car for about a 1/2 a lap
Matt Howard is offline
Old 10-26-2004, 12:19 AM
If it's a new motor i'd skimm (cut the comm) a little bit because some times the comms are not straight from the factory and then i'd put on some new brushes and run it in for 20 seconds on 3v
Chazz
Chazz is offline
Old 10-26-2004, 12:46 AM
S-T-R-l-K-E-R's Avatar
this is a touchy topic. my advice to you is keep your mind open because if you ask 6 people on how to break in a brush and i'm sure that you would get 9 (or more) diffrent answers.
i break in the brush depending on its hardness. if the brushes are of a soft compound it would take about 4 mins at 3V. if the brush compund is harder then obviously it would take more time to do it.
S-T-R-l-K-E-R is offline
Old 10-26-2004, 02:01 AM
pink pac man's Avatar
i just chuck it on the track and strap it around for a couple of laps
pink pac man is offline
Old 10-26-2004, 04:10 AM
Default break in
So no one really runs them with a load??? as an example...under water???
The reason i'm asking is we ran my Chamelion 2 on the dyno for a couple of minutes till max rpm....let it cool down and did it again and the rpm came up...this happened a couple times...so if you just run it on the stand for 2-3 minutes are you really breaking it in????
6Cuda6 is offline
Old 10-26-2004, 04:38 AM
Trader Rating: 70 (100%+)
6Cuda6-We dont use water anymore unless it's a closed endbell 540 or something.
The OLDER brushes werent shaped like today's brushes and water worked very well with them.
Cheap Way-Put the motor in the car of choice and hold the throttle 1/8-1/4 throttle for 2-3 minutes.Then go Practice or strap in a new battery and get ready to race once the motor has cooled down.
Right Way-With most of today's Brushes simply break in the motor with NO load for 4-5 minutes on 2volts.
Remeber to Lube Bushings Or Bearings before break in.
Do NOT use a break in Drop.
TexRacer is offline
Old 10-26-2004, 04:46 AM
Default break in
Thanks guy's...theres just to many rumors out there....
6Cuda6 is offline
Old 10-26-2004, 04:52 AM
so whouldent running it on the track be running it under a load
Old 10-26-2004, 05:11 AM
X2
X2's Avatar
Running it under too much load increases amp draw and arcing, not good.
With a cut com and new brushes, try breaking in the motor at 2V for 4-5 mins, then give a light re cut and then break it in for about 30 secs at 3V. Usually gives good results. (this is all under no load)
X2 is offline
Old 10-26-2004, 05:24 AM
fatdoggy's Avatar
As has already been said, 2v for 3-5 minutes.
fatdoggy is offline
Old 10-26-2004, 08:04 AM
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
run the motor at a low voltage 3v-4v until, for full face, all of the face of the brush is touching the comm, for serrated, so that the ends of each serration is touching the comm. sometimes 3mins etc might be too long and you just end up wasting the brush and if it has them the serrations.
dontfeelcold is offline
Old 10-26-2004, 08:09 AM
johnnywhopper's Avatar
i do mine @ 1v w/ a fan blade for 200 seconds. then check amp draw at 2v. usually ends up around 10.5 - 11.5 amps for a monster stock.
johnnywhopper is offline
