Old 09-19-2011, 01:26 PM   #106
EricF's Avatar
Josh-
What's the offset on the rear wheels?
Thanks,
E
AE 12R5.2 & R6(x2) - TC7.1 convert, F6 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 09-19-2011, 01:33 PM   #107
Josh Cyrul's Avatar
19mm... We went to a centered mounting face to ensure the tires run as true as possible. It also allows us to have a really stiff front face for corner speed and a soft inner for traction and drivability.
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 09-19-2011, 10:07 PM   #108
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Nice looking rim and glad to hear we can expect a true quality rim. Will u offer pre mounted? Will you offer the rim in a other color. Black is so hard for us old guys to pick up against ozite. Bright green comes to mind. Also, did you have a chance to look for any Phoenix WGT's?
Thanks, Carl
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 09-20-2011, 12:26 AM   #109
29TC's Avatar
Send a message via ICQ to 29TC
Any updates on the updated EVO parts?
29TC is offline   Reply With Quote
Old 09-20-2011, 01:16 AM   #110
Josh Cyrul's Avatar
Carl - Shoot... I'll look at that WGT stuff in the AM. Sorry... Yes, we will have mounted tires - Looking at about 6 compounds for fronts and 6 for rears to start. Sorting out all that right now. Black is an easy color that matches cars/schemes - I really don't like white 1/12 rims and if we went with yellow, green or another color someone will always compain..lol... Black was a safe/easy one and honestly, my fav for 1/12 rims.
29TC - Yes, I was unhappy with the samples that arrived so I passed on that supplier. The one that I like has done up some samples and they look great! I gave them the go ahead for production so they may be in stock before the IIC. From there, we have graphite on order so when it arrives we will be able to start cutting graphite for them. May just have a limited # available before IIC due to time constraints but after the race they will be in full swing.
Old 09-20-2011, 01:21 AM   #111
Josh Cyrul's Avatar
Here's a pic of the samples - They are not anodized but will be black anodized in production.
Old 09-20-2011, 01:29 PM   #112
EricF's Avatar
Will you have tire and hubs at the IIC and how many? I'm coming in early to mid day on tuesday.
Thanks,
E
Old 09-20-2011, 01:37 PM   #113
Hey Josh I will be flying in on the 27th for the iic race in Vegas just to look around and probably shop will you have any of the griffin in line conversion the 75$ dollar one there I will pick one up from you if you have it. Thanks
Lizardboy76 is offline   Reply With Quote
Old 09-20-2011, 01:41 PM   #114
jkirkwood's Avatar
Josh - The only thing I need to update my original Griffin to the 2011 spec is the upgrade chassis? Any other parts I should order?
Also, could you post or send me a starting 1/12th modified setup. Thanks.
SMC Racing | AKA Products | SANWA
jkirkwood is offline   Reply With Quote
Old 09-20-2011, 09:55 PM   #115
Josh Cyrul's Avatar
EricF - We will have very limited #'s. Honestly, I may be bringing donuts and stripping rims and re-mounting at the race if we need too..lol... I should have at least 50 sets of rims but if the few of us who will run them decide to sway off the usual compounds then we may have to do a little extra work. Also, I only have 3 sets of sample hubs right now and those are already reserved for myself and 2 other CEFX drivers. The production ones may arrive right before the race and if they do then we could possibly supply a few more racers with tires at the event.
Lizard - IIC is October 3rd-8th. If you are coming in on the 27th you will be a bit early (or really late if October). If you will be there, I can make sure to bring one for you.
jkirkwood - You would need the update kit - Includes the chassis, center shock mount, standoffs and hardware. We also have all the new aluminum front end parts. Those will be going up on the site here shortly.
I will get some set-ups posted here soon. We were able to test the inline version with Pete at the IIC Warm-Up and it definatly needs a little different center shock set-up.
Old 09-20-2011, 11:01 PM   #116
CypressMidWest's Avatar
Josh, The wheels and hubs look AWESOME.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 09-21-2011, 02:47 PM   #117
Khador12's Avatar
Put the upgrade kit on my Griffin12 last night and I have one question. I am using the Thunder power 65c 5400 mah battery and it fits really snug under the shock mount and rear brace, is this normal? If not should I shim them up?
Billy Stewart
Xray T4 17
Roche Rapide F1 Evo
Khador12 is offline   Reply With Quote
Old 09-21-2011, 04:04 PM   #118
Josh Cyrul's Avatar
Ian - Thanks!!
Khador12 - Yes, depending on the battery pack you are using you will need no shims or as much as .75mm to clear the pack.
1/12 tire compounds are decided on as well as prices and part #'s. Those will be posted here soon. The 1/12 hubs are in production now and should be in stock as early as late next week along with the new WGT right hub and Evo motor/mount plates. The tire truing arbor will be coming the following week while we are at the IIC. 2nd test shot of the rims is done and shipping so the final wheels will be in production next week once we recieve this 2nd test shot and approve. We expect to be able to ship 1/12 tires around October 14th-21st range.
Progress continues here as quickly as possible!
Old 09-21-2011, 07:05 PM   #119
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to ToysRUsKid
I went to the website and almost pre-ordered the upgrade kit...patiently waiting for my griffin
Dorian Tisdale - Professional RC Driver Wannabe
ToysRUsKid is offline   Reply With Quote
Old 09-21-2011, 07:08 PM   #120
ToysRUsKid's Avatar
Ian - Thanks!!
that's good to know because I just bought 3 of these batteries.
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 01:53 PM
2011 ROAR Carpet Nationals at Timezone II March 24th-27th MAD916 Electric On-Road 654 09-29-2011 09:47 PM
CEFX 2010 - A new Evolution. Josh Cyrul Electric On-Road 823 07-04-2011 05:10 AM
The 2011 Snowbird Nationals / January 25th-30th RCThunder Electric On-Road 400 07-01-2011 12:09 PM
