Old 02-23-2012, 09:07 AM   #526
Trader Rating: 15 (100%+)
I recently acquired a Griffin 12 and have been racing with it for the past 3 weeks or so, mainly playing around with the inline battery position and trying to figure out good setups I like for the car. Setup is always a work in progress, but I already know that the CEFX is an awesome car. Incredibly consistent, drives awesome, and very well made. I am looking forward to trying out the new CEFX tires at some point, but I am honestly afraid that I might get hooked on them
Thanks for making great products Josh, I am a huge fan!
LloydLoar is offline   Reply With Quote
Old 02-24-2012, 04:27 PM   #527
avs
avs's Avatar
Tony Shimko
avs is offline   Reply With Quote
Old 02-29-2012, 04:11 PM   #528
sprintcarracer's Avatar
Trader Rating: 25 (100%+)
Has anyone tired using linner tweak springs on there griffin 12. If so what diffrence did you see.
sprintcarracer is offline   Reply With Quote
Old 02-29-2012, 05:37 PM   #529
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey sprintcarracer,
The Linear Tweak Springs smooths out the car. It just makes it easier to drive.
Smooths out the car when it feels edgy on high bite. And on Low bite tracks it improves traction.
Hope this helps
Mike
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 02-29-2012, 10:21 PM   #530
kuruption's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to kuruption
I'm looking to guild a Griffin 10... WGT has started to pick up in popularity in our area, and I know there are guys that run them outdoors, so I figured I'd put one together... I'd like to do it with as many CEFX parts as possible, i.e. using the new front end components.
Hoping I could get a little help from Josh or others who have tried the same thing. I plan to use an HB shock and linear teak springs like in my 12, but as for the others...here's what I'm thinking I need. Anything else anyone can think of? I don't want to place multiple orders...
Here's the list I've come up with... please let me know if there is anything I should add or subtract.
11009 Griffin 10 Conversion Kit
11051 R5 suspension arm mount
11015 Inline Axle Set
11124 Front End Brace Tubes
10102 Frontend Bulkhead (x2)
10103 Griffin Arm Insert
10104 Griffin 0* block (x2)
10107 Griffin 10 Ball Stud Kingpin
10108 Hinge Pin
10114 Linear Spring Cups
12607 Servo Mounts
I believe I read the rear axle and diff assembly is also needed? If that is the case, I need to add...
12400 Rear Axle
10121 Griffin 10 Right Hub
11401 Left Hub
But man looking at it now, if I add all of that up, I'm looking at a $340 tab still missing several parts, including bearings and some AE components to finish it up. So coming in close to $400 for a kit, and wow... that's $100 more than other kits out there like the X-10 and Rebel 10. Any discounts available?
Ray Sundland
Eat. Sleep. Race. Repeat.
"Feel not as though it is a sphere we live on, rather an infinite plane which has the illusion of leading yourself back to a point of origin."
kuruption is offline   Reply With Quote
Old 03-01-2012, 08:06 AM   #531
Josh, thanks for the prompt shipping. Just got my tires in yesterday.
The Z4s look great, I can't wait to try them out. Hopefully I will have an arbor machined by the 10th, which will be the last race/test day before the track shuts down for the Carpet Nats.
Quick question, I noticed the Black/Grey fronts and Grey/Yellow rears are now on backorder. Any timeframe/eta on re-stock?
Also, the tires marked as "X" on the website... what is that compound/durometer/rubber type?
JamesL_71 is offline   Reply With Quote
Old 03-01-2012, 11:11 AM   #532
MarkBurgess's Avatar
10108 Hinge Pin
12607 Servo Mounts
12400 Rear Axle
11401 Left Hub
I had offered to list the parts I used from a 10R5 to build my Griffin 10. That I can still do...just not today.
For me I'm happy with the car as it's built up that way, and haven't thought too hard about a longer shopping list. However I can take a look through that list and see if anything stands out
Might have some time to do that this weekend
MarkBurgess is offline   Reply With Quote
Old 03-01-2012, 03:30 PM   #533
I believe X is softer than Pink and in the same family.
MHR
Highside20 is offline   Reply With Quote
Old 03-02-2012, 12:59 AM   #534
303slowdown's Avatar
Hello i just receive my tire order and have a question. I was running parma black fronts and orange rears and switching to the z4's (black/gray fronts and gray/yellow rears) i slowed down 2 tenths a lap. I know the gray/blacks are softer so what do i change to gain the corner speed back. I usually run harder front tires and now the car feels squishy ,so any help on what to change would be great. Also i put the parmas (fronts only ) back on for the main and gained my 2 tenths back.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 03-02-2012, 08:47 AM   #535
Interesting...
Based on your description, the first thing I might try would be a slightly stiffer front spring to keep the front end from biting quite as hard.
Old 03-02-2012, 09:05 AM   #536
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Correct. X's are a super soft pink (usually in the 20-23 durometer range).
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 03-02-2012, 11:11 AM   #537
peter_robinson's Avatar
Trader Rating: 21 (100%+)
Try team purple front (lilac), I think Josh mentioned that more compounds are coming as well... Don't quote me tho.
For orders or inquiries, email [email protected] Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 03-02-2012, 12:02 PM   #538
Any word on the 10R5 chassis being added to the online shop?
Serzoni is online now   Reply With Quote
Old 03-02-2012, 12:06 PM   #539
Does anyone have actual in-car pictures of the Griffin 12 bulkheads ( http://www.cefxspeedshop.com/10102-G...head-10102.htm ) and the 0,5, and 10 blocks ( http://www.cefxspeedshop.com/10104-G...lock-10104.htm , http://www.cefxspeedshop.com/10105-G...lock-10105.htm ) ?
I am curious to see exactly how these differ from the normal AE ones, but it is difficult to tell just using the cad photos on the CEFX website.
Old 03-02-2012, 02:02 PM   #540
avs
avs's Avatar
there was a picture of a car with these parts maybe 2 pages back (latif's car). it looked like the main differences were that the bulkheads are threaded for the lower arms (there are new inserts 10103 required) and the castor blocks are alloy compared to the plastic AE part.
Tony Shimko
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 01:53 PM
2011 ROAR Carpet Nationals at Timezone II March 24th-27th MAD916 Electric On-Road 654 09-29-2011 09:47 PM
CEFX 2010 - A new Evolution. Josh Cyrul Electric On-Road 823 07-04-2011 05:10 AM
The 2011 Snowbird Nationals / January 25th-30th RCThunder Electric On-Road 400 07-01-2011 12:09 PM
