Old 02-12-2012, 09:24 PM   #496
peter_robinson's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Highside20 View Post
Josh,
Do the Z4 front rims use flanged or non-flanged bearings?
Thanks,
Flanged
For orders or inquiries, email [email protected] Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 02-12-2012, 10:00 PM   #497
Originally Posted by peter_robinson View Post
Flanged
Thank you!
MHR
Highside20 is offline   Reply With Quote
Old 02-14-2012, 07:52 AM   #498
sprintcarracer's Avatar
Trader Rating: 25 (100%+)
Since my ball diff building skills are very poor I'm looking for help. I start with 400 grit and work my way up to 1200 grit. The rings look very nice and flat but not polished just faint cross hatch marks. But when I assemble the diff it is not smooth but fella very thight. I just can't seem to get that silky smooth spin that everyone else gets. I'm just wondering how others build there diffs. I have hours into one now and I think I would be better off just installing new untouched rings and running the car that way.
sprintcarracer is offline   Reply With Quote
Old 02-14-2012, 08:16 AM   #499
xtrememadness's Avatar
Send a message via AIM to xtrememadness
Hey josh did you add those 10r5 chassis to the speedshop? Cant seem to find it. Thanx
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 02-14-2012, 08:31 AM   #500
wingracer's Avatar
Trader Rating: 24 (100%+)
The balls and rings are not the only place crunchiness can come from. Replace your outer bearing in the hub or get go to a thrust bearing.
Did you replace the balls? Steel or ceramic?
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 02-14-2012, 08:47 AM   #501
This. When I rebuild my diffs, I *always* test them out with a brand new outer bearing. Then I retest with my previously used outer bearing and compare the smoothness. That should give you a good indication of whether or not it is time to replace.
Also, I sand with much higher than 1200grit for the final step. I go 400, 600, 1200, 2000.
Something else that some people tend to overlook, is which side of the rings you choose to prep. The diff rings develop high spots, obviously... this is why we sand/prep them. But some rings develop the high spots toward the outer edge, others develop them towards the inner center. When I am prepping new rings, I always *lightly* sand both sides on a *perfectly* flat surface. Then carefully inspect both sides... you will see a slightly scratched/shiney surface starting to appear, which is where the sandpaper has removed material from the surface of the diff ring. The side you want to continue prepping will be the side where the scratched/shiney surface is developing towards the outer edge of the ring.
JamesL_71 is offline   Reply With Quote
Old 02-15-2012, 09:22 AM   #502
All of the bearings are good. I replaced the balls and they are steel. Where can I get a thrust bearing and do you sand those rings just like the diff.
Old 02-15-2012, 09:37 AM   #503
burgboyz's Avatar
Trader Rating: 70 (100%+)
Default Thrust Bearings
I like these...
http://www.slapmastertools.com/thrust-bearings.php
Got Droop???
Speed Passion....Speed Power....Serpent America/Desoto Racing.
burgboyz is offline   Reply With Quote
Old 02-15-2012, 12:09 PM   #504
Josh Cyrul's Avatar
Sorry guys, been down sick the past few days.
Diff - I never, ever sand rings. Unless they are horrible there really isn't reason to build a good diff. To me, there are a few critical things to a good diff:
#1- Good outside bearing. I don't like the thrust bearings and only recommend them if you crash a lot. At $1.00 each on our shopping site, no reason for expensive thrust that in my opinion doesn't build any better of a diff.
#2- Ceramic balls to me are a must. They are more round, won't flat spot and I've run the same sets for over 2-3yrs. Also, when building my diff I leave it loose and hold 1 tire + spur and crank other tire - makes a squeaking sound but super hard ceramic balls actually cut the groove into the rings making sanding rings a waste of time.
#3- Only use AE diff grease w red writing - again sold on CEFX site. This grease has perfect mix of abrasive so diff doesn't slip, is smooth and is super free.
#4- Spur is critical. I haven't tried some of the new CRC or Xenon gears but the only spur you will ever see in my cars w diff is kimbrough. Honestly, most other spurs (machined) build terrible diffs.
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 02-15-2012, 01:29 PM   #505
Thanks Josh. I will pick up new diff bearings and new rings, I have the cramic balls.
Old 02-15-2012, 01:45 PM   #506
Hello Josh,
What is your deadline for placing Z4 tire order for nats?
Thanks!
MHR
Old 02-15-2012, 04:15 PM   #507
Looking forward to trying out the Z4s on my 12th
Old 02-16-2012, 03:23 PM   #508
Xpress's Avatar
Anybody have any experience with the CEFX Xray chassis?
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 02-16-2012, 03:34 PM   #509
+1 to this. All I use is Kimbrough as well. It's impossible to have a great diff without one.
Old 02-18-2012, 12:28 PM   #510
Xpress's Avatar
Anybody know if Josh is out of town racing? Placed an order for an "in stock" item Monday and haven't received shipping info yet?
-Espo
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 01:53 PM
2011 ROAR Carpet Nationals at Timezone II March 24th-27th MAD916 Electric On-Road 654 09-29-2011 09:47 PM
CEFX 2010 - A new Evolution. Josh Cyrul Electric On-Road 823 07-04-2011 05:10 AM
The 2011 Snowbird Nationals / January 25th-30th RCThunder Electric On-Road 400 07-01-2011 12:09 PM
