Old 12-14-2011, 03:14 PM   #346
Originally Posted by vabroom View Post
If you are talking about the center pulley mount, most Photons are setup using one screw. It lessens the chance of tweaking the chassis.
That is a very good point. Iím hoping the second screw will not cause any tweak mainly because the bulkheads are steel and they sit atop another CF plate before mounting to the main chassis.
MHR
Highside20 is offline   Reply With Quote
Old 12-14-2011, 05:42 PM   #347
haywood's Avatar
Trader Rating: 49 (100%+)
Default Evo
With the release of the Evo has Josh been around to support his products?
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 12-14-2011, 06:10 PM   #348
Trader Rating: 55 (100%+)
Not really a fair question. Cefx car kits, In my opinion, are more a specialty kit. He has said time and time again, he is a 2 person operation. If you dont wanna buy his stuff, dont buy it. Most of us have grown to really appreciate his design skill, and can use an email of pick up a phone. I dont see the "owners" of AE, Xray, Tamiya, Corally or TOP following Rctech to answer every single question. If you cant figure out a set up, these are probably not the kits for you.
Jamison R is offline   Reply With Quote
Old 12-14-2011, 06:12 PM   #349
haywood's Avatar
Thanks! For the record I can setup a sedan quite well!
Old 12-14-2011, 06:17 PM   #350
Buckaroo's Avatar
Yes, set up using only one screw, but with a headless setscrew on the other side for full support. Mainly to prevent the aluminum bulkhead from tweaking the chassis.
Much less chance of that with the Evo design. I'm thinking I just might have to place an order very soon!
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 12-14-2011, 07:55 PM   #351
ByteStream's Avatar
Well it's been almost 2 weeks since I received the wrong item .. I have sent numerous emails, pm's and posted here and have had no response whatsoever. I know he is busy but so are alot of people this time of year.
If anyone has contact with Josh, please let him know there is an issue that needs his attention.
RCAmerica | Xray | Hudy | KO Propo | Hobbywing HWNA | R1Wurks | BSR Tires
5280 Raceway - www.5280raceway.com
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
ByteStream is offline   Reply With Quote
Old 12-14-2011, 08:13 PM   #352
+1
MHR
Old 12-15-2011, 09:56 PM   #353
snoopyrc's Avatar
This question doesnt really have anything to do with the EVO but just a general TC design question. OK so what is wrong with putting the motor in the center of the chassis and using a higher layshaft to get the belts over the other gear and battery? Like the FK04 or 414MII. Expecially with the FK04. Why did they not keep the motor and battery in the center like that? Why do you only see old stuff and low end stuff (Sprint 2 sport) layed out like that?
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 12-19-2011, 05:05 AM   #354
MarkBurgess's Avatar
Pleased to report Griffin 10 build completed on Saturday. Thankfully my F1 was running well so got a lot of time to work through the finer details.
First run in open practice at the end of play Saturday went very well. Gave me a good chance to shakedown the car and get a feel for 13.5 blinky running before the Snowbirds. Went very well so now making plans to run the Griffin in our January meeting just before the Birds.
MarkBurgess is offline   Reply With Quote
Old 12-19-2011, 01:18 PM   #355
how much of a rebuild did the shock need Mark ?
CPD Racing
chris_dono is offline   Reply With Quote
Old 12-19-2011, 03:25 PM   #356
Crisis turned out to be a reliable postman...who knew
After speaking to Jason and Gav I'd decided to fit a CRC Encore shaft and the adjuster to fit a 4-40 on the end. Means I can run the CRC bottom shock cup which makes changing the spring easier.
That meant a refill of the shock oil of course
The fiddly bit was getting the length right. I'd used a long 4-40 threaded rod to get a Silva concepts shock to fit. The HB shock is longer so it made the shock too long. Thankfully I had an AE standoff in a parts box which was the ideal length. Sorted.
Thanks again for getting the shock to me. Meant I could finish the build and get some proper Snowbirds shakedown runs in
Old 12-20-2011, 05:41 PM   #357
You're very welcome ! Will keep an eye on the results and looking forward to the obligatory postcard
CPD Racing
Old 12-23-2011, 04:42 AM   #358
Of course there will be the famous "Postcard from..." thread for my Snowbirds trip
Will also post photos of the finished car soon.
Old 12-27-2011, 11:12 AM   #359
Photos as promised
Old 12-27-2011, 11:21 AM   #360
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
^^^ Fabulous^^^
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 01:53 PM
2011 ROAR Carpet Nationals at Timezone II March 24th-27th MAD916 Electric On-Road 654 09-29-2011 09:47 PM
CEFX 2010 - A new Evolution. Josh Cyrul Electric On-Road 823 07-04-2011 05:10 AM
The 2011 Snowbird Nationals / January 25th-30th RCThunder Electric On-Road 400 07-01-2011 12:09 PM
