Old 12-10-2011, 09:04 AM   #316
wingracer's Avatar
Trader Rating: 24 (100%+)
Anyone have an extra Griffin motor plate? Or know of another brand that fits? I have a cracked one and it looks like Josh is out of them.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 12-10-2011, 09:12 AM   #317
Khador12's Avatar
I noticed the same issue with spur size and just replaced with a bigger one. Watch which way you put your pinion on, it may rub on the front belt. The steering is a little tight but I did use some 600 grit sand paper to free it up. Do not sand to much because Josh did say they show wear quickly.
Billy Stewart
Xray T4 17
Roche Rapide F1 Evo
Khador12 is offline   Reply With Quote
Old 12-10-2011, 09:46 AM   #318
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
I was going to get one until someone pointed out his motor mount bandade .
If he ever gets in gear and produces the kit with all the correct parts I will have me one .
But not going to be burned again with them bendable motor mounts like last time.
Let me ask tc owners this ,had anyone other than me and my 2 travel guys ever tweaked a camber plate on a photon or cefx ? I/we have about 6 plates that r either bent(unlaminated) or the screw cut thru the carbon and now are junk.
On the new EVO if this happens .........does this bring up a expensive problem?
All it takes is one moron to hit u in the wheel and mess up the camber plate "area" of the top deck... Theirs $50 and who knows how long to get a replacement.
On the new photon and old this is only a $7 fix
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 12-10-2011, 02:34 PM   #319
Khador12's Avatar
With the old Evo I never had an issue with the motor mount. With the Evo the two sets of the old motor mounts will work until he sends out the new ones. I have not seen the issue with the camber plates, I do make sure all hardware is tight on them though.
I do not mind ordering from CEFX because the products are well worth it! Keep up the good work Josh, Angel, and those that have helped them keep up.
Billy Stewart
Xray T4 17
Roche Rapide F1 Evo
Old 12-11-2011, 06:15 AM   #320
wingracer's Avatar
Anyone? I really need one of these by the weekend.
Team Shepherd USA
Old 12-11-2011, 07:39 AM   #321
haywood's Avatar
Trader Rating: 49 (100%+)
Here is a repair kit!
http://www.rctech.net/forum/r-c-item...hlight=Griffin
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 12-11-2011, 08:10 PM   #322
wingracer's Avatar
I think I found one. Are the old green ones the same as the old style black ones? I know the new blacks are different but I have the old blacks and found a green.
Team Shepherd USA
Old 12-11-2011, 08:27 PM   #323
Infinite 12th's Avatar
The old green are very foamy
The old black we're very rubbery
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 12-11-2011, 08:30 PM   #324
wingracer's Avatar
I'm talking about motor plates, not tires
Team Shepherd USA
Old 12-11-2011, 08:44 PM   #325
Got most of the EVO built (still waiting on the bearings). I built mine using mostly TF6 parts such as the TF6 gear diffs, axles, shocks and suspension arms. I have a ton of the TF parts so that is why I went that direction. I used the TOP suspension pickups, 3Racing center pulley and some XRAY hubs.
MHR
Highside20 is offline   Reply With Quote
Old 12-11-2011, 09:20 PM   #326
303slowdown's Avatar
Car looks very nice ,nice job making electronic install look so good
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 12-11-2011, 09:25 PM   #327
haywood's Avatar
Default Looks great!
1380 with a shorty? I have a feeling you will need some weight on that ride!
Old 12-12-2011, 06:57 AM   #328
Buckaroo's Avatar
Could someone please post a few pics of the battery side of the Evo? Thanks.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 12-12-2011, 08:04 AM   #329
Khador12's Avatar
Here are some pics of the battery side. There is a locator on the inside both front and back. The fit is good on the locators and the tape slots are right at the edge of the battery. In the picture without the battery you can see some of the almost 100 grams of weight added to make weight. The piece used is from the photon balance weight set, it is cut down to length and notched for the servo to fit in where I have it.
Billy Stewart
Xray T4 17
Roche Rapide F1 Evo
Old 12-12-2011, 08:48 AM   #330
Rick Vessell's Avatar
Yes the old plates are the same, just different colors.
I've not had any problems with the old camber plates. In testing the new top deck was pounded pretty hard and did not fail.
As for the motor mount, you're getting two in the kit to use until the new production comes in. That's better than getting one of the current old stock in the kit and then you have to order another one if you bend the first. Hardly a band-aid IMO.
Rick Vessell is offline   Reply With Quote
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 01:53 PM
2011 ROAR Carpet Nationals at Timezone II March 24th-27th MAD916 Electric On-Road 654 09-29-2011 09:47 PM
CEFX 2010 - A new Evolution. Josh Cyrul Electric On-Road 823 07-04-2011 05:10 AM
The 2011 Snowbird Nationals / January 25th-30th RCThunder Electric On-Road 400 07-01-2011 12:09 PM
