Old 07-19-2011, 07:37 PM   #1
Monteman's Avatar
Trader Rating: 16 (100%+)
Default Servo Recommendation
Looking for a servo to replace the stock servo in my TC4. Without going insane on it (trying to keep it under $70) what would be the ideal servo for me as an upgrade. Doesn't need to be the best of the best obviously, just a little more response and torque than the stock unit. Not going to be racing anytime soon.
Cameron - Edmonton Canada
** Every time see someone use their first post to necro-bump a 4 year old thread all I can think is "at least they used the search function" **
Monteman is offline   Reply With Quote
Old 07-19-2011, 08:01 PM   #2
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
Savox SC-1251MG
It's low profile so it's smaller and it's high-speed metal-gear so it'll last you.
http://www.amainhobbies.com/product_...tal-Gear-Servo
Fishhook
ewashburnaf is offline   Reply With Quote
Old 07-19-2011, 08:43 PM   #3
Originally Posted by ewashburnaf View Post
Savox SC-1251MG
+1
Cheap, small, light, fast, torquey enough for TC, cheap replacement gear sets... I've got two and haven't noticed any perf difference when compared with my BLS551. I did strip one when running without a servo saver, but that was a cheap fix.
-Mike
Old 07-19-2011, 09:13 PM   #4
Monteman's Avatar
Does the Associated servo arm assembly match up with the Futaba spline, or do i have to swap out more parts than just the servo?
Old 07-19-2011, 10:18 PM   #5
rc_square24's Avatar
The kit only came with one servo arm?
If you order from savoxusa shipping is free and you also get a tshirt
rc_square24 is offline   Reply With Quote
Old 07-19-2011, 10:32 PM   #6
Monteman's Avatar
if by kit you mean the car it was RTR and there are no alternate servo parts in the box. i haven't bought a servo yet, there's nothing i dislike more than making return trips to the LHS for small extras that i didn't ask about ahead of time.
Should there be more servo horns that came with the car? Or are you talking about horns that are included with the savox?
Old 07-19-2011, 10:57 PM   #7
Monteman's Avatar
and just to add, the stock horn in the car is not marked either way as they are in the kit from AE #9180
Old 07-20-2011, 01:01 AM   #8
I just looked up 9180 and it says its got horns to fit all servos.
If you have that part tree then you're good, if not you'll have to buy it.
But if you have the RTR which I believe is Asso's XP brand radio, they should be Futaba spline count already, which is the same as Savox.
Best to check if your servo is 25 spline (which fits Futaba, Savox).
** Actually here u go: http://www.rctech.net/forum/radio-el...ba-thanks.html
Old 07-20-2011, 07:02 AM   #9
Monteman's Avatar
sweet thank you
Old 07-20-2011, 07:31 PM   #10
you might want to try using a medium sized "servo saver" instead of a servo horn as well... just another option that will help preserve the life of your servo
Fishhook
Old 07-20-2011, 08:10 PM   #11
Monteman's Avatar
isn't there a servo saver built in with the steering linkage under the shock tower?
or am i just too familiar with Traxxas lol.
Do you have a link or anything for what you are recommending?
Old 07-20-2011, 10:12 PM   #12
yep... it looks like this and this is the actual one I use.. it comes with three different adapters so it'll work with any servo out there...
http://www.amainhobbies.com/product_...tec-Airtronics
Fishhook
Old 07-20-2011, 10:15 PM   #13
Monteman's Avatar
crap, i just put an order into amain this afternoon. d'oh!
but LHS to the rescue, they actually have stock. nice.
Old 07-20-2011, 11:03 PM   #14
Extra safety is good, but in the seven years ive had my KO 2143 i've never had a problem with using just the chassis saver on any car its been in. (knock knock knock)
Throttle Servo Recommendation for an RC8 Captpete Nitro Off-Road 15 08-08-2008 06:18 PM
