Old 07-18-2011, 04:34 PM   #1
cheehtae's Avatar
Trader Rating: 15 (100%+)
Default Tamiya aluminum servo saver
I installed this in my car and it has alot of play, how do you guys use this or get rid of the play.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 07-18-2011, 04:42 PM   #2
did you install it correctly? there should be two metal c-clip springs installed with it. If installed correctly there should be no play.
swarb is offline   Reply With Quote
Old 07-18-2011, 04:47 PM   #3
cheehtae's Avatar
I thought I did. Hmmm..
Old 07-18-2011, 07:11 PM   #4
Trader Rating: 69 (100%+)
If you use the High Torque Servo Saver, the C springs require replacement after some usage. Alternatively, when they become "loose", i.e., not centering correctly, you can remove them and use pliers to clamp the C springs close and reinstall again. But eventually they will lose tension and need replacement.
eComet is offline   Reply With Quote
Old 07-18-2011, 07:40 PM   #5
cheehtae's Avatar
so correct me if I'm wrong with my assembly, silver or the bright spring first followed by the black?
Old 07-18-2011, 07:46 PM   #6
You should have two bright springs and a black one. Get the first bright spring (doesn't matter which), and then the second bright spring over it, then slide the black spring over the two bright springs.
Old 07-18-2011, 07:58 PM   #7
cheehtae's Avatar
That's what i did at first,,,, will take some pictures and post it maybe tomorrow. Thank you for the reply. Till tomorrow.
Tamiya mini cooper sipaboy Electric On-Road 29687 12-10-2017 04:07 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
Does anyone not run a servo saver? pakk Electric On-Road 12 06-03-2011 06:40 PM
