Old 07-15-2011, 07:06 PM   #1
Default How much more speed are we talking?
I have a HPI Sprint with a Tacon 3500kv motor and on 2s it does 34 mph. Im going to try and post a pic but Im on my phone and not sure how. Anyway, what kind of speed can I expect to see changing ONLY the motor to 4420kv? Same gears same battery. Thanks!
http://m1093.photobucket.com/albumvi...1hoUS%2BRzA%3D
LST2 E BL, Losi 8ight RX8/2150kv,
TC3 BL, Losi XXXSCT BL
jrowles91 is offline   Reply With Quote
Old 07-15-2011, 08:55 PM   #2
Changing motors without changing gearing is a bad idea, you will most likely overheat the new motor and either damage or destroy it. Your adding another 7,000 rpm approx. (1,000 rpms per volt)
Assuming your geared correctly now your going to ask the new motor to spin beyond what it should. If you start by monitoring temperatures you can see how it goes.
You can use this site to figure out approximate mph for your setup with different gear ratios. http://gearchart.com/
Syxxstring is offline   Reply With Quote
Old 07-15-2011, 09:31 PM   #3
Yeah I realize that doing this would create more heat but I just wanted a ballpark so I knew whether it was worth replacing a perfectly good motor with another one. Thanks for that link though, I'll try and input my stuff and see what happens! Thanks!
Old 07-16-2011, 05:58 AM   #4
phildoggg's Avatar
Trader Rating: 24 (100%+)
speed estimator here.
http://scriptasylum.com/rc_speed/top_speed.html
phildoggg is offline   Reply With Quote
Old 07-16-2011, 08:28 AM   #5
Originally Posted by phildoggg View Post
I don't know everything to make this one work. I use this one for my trucks!
Old 07-16-2011, 12:00 PM   #6
Quick question about this. When using temps to find good gearing, how long should I run the kit before taking the temp? And should I run it as hard as I can to get the temps as high as possible to know whether to gear it down more? Also, is there a general rule that 1 tooth is worth x amount of degrees or something like that? I can't afford to spend a bunch on gears I'll only use to figure out gearing and won't use again. Thanks! I bought the 4420kv btw.
Old 07-16-2011, 03:15 PM   #7
mr fit's Avatar
what speedcontrol are you using... Run the car for 1 minute at your track or your street/ parking lot. Then take a temp. If reaches 140f degrees then you are overgeared. Run the car 1 minute at a time until you reach 5 minutes. Then you can run it 5 minutes completely Motors can run safely at 165f degrees. A 4420kv motor is equivalent to a 10.5 motor. With proper gearing, timing and boost ( if your speed control has it ) you can get it up to 60mph. Start a 8.0 fdr with timing and boost. No timing and boost 7.0 fdr.
marc davila aka... marc ups.... drive it like you stole it.
mr fit is offline   Reply With Quote
Old 07-16-2011, 05:54 PM   #8
I'm using the Ezrun 60a esc. Ok so when I get the new motor I'll play with it. I don't have a temp gun though. Is there a touch measurement like they use with nitros (using spit, yes spit on the head of the motor)?
Old 07-16-2011, 10:21 PM   #9
http://www.harborfreight.com/non-con...ter-93983.html
Old 07-16-2011, 11:01 PM   #10
MattFromSooke's Avatar
Send a message via Skype™ to MattFromSooke
you should be able to hold your fingers on the motor, if it burns your fingers its too hot.
6 Ps of racing: Proper Preperation Prevents Piss Poor Performance
MattFromSooke is offline   Reply With Quote
Old 07-17-2011, 01:33 AM   #11
ozzy-crawl's Avatar
Trader Rating: 14 (100%+)
MST XXXD vip
MST FS-01d
Xray T4
Xray T3
AE Sc10.2 AE SCB
ozzy-crawl is offline   Reply With Quote
Old 07-17-2011, 01:47 AM   #12
For me though that's only about 130 degrees. Oh well, guess I'll just have to get a temp gun.
Thanks everyone for your input.
Old 07-18-2011, 12:15 PM   #13
mr fit's Avatar
You can buy a decent temp gun for about $20. With an ez run 60a you are not gonna get blistering speeds. I believe that esc only has motor timing. I would not put any motor higher than 4420kv motor you have. That esc is meant for stock racing. eg; 17.5, 13.5 and maybe 10.5
Old 07-18-2011, 02:16 PM   #14
Yeah I figured that. I actually bought that esc for my kids Evader. Worked well on that, but then I got this car and wanted to hop it up.
Old 07-18-2011, 04:02 PM   #15
Rick Hohwart's Avatar
If you can touch your motor without burning your fingers after a run you are not working it hard enough.
Rick Hohwart is offline   Reply With Quote
Much-more cell master . cyclone speed Electric On-Road 18 01-27-2009 12:26 AM
nitro sell out o.s speed,go tech, sts losi 8 b kcpipeliner R/C Items: For Sale/Trade 64 12-29-2008 06:49 AM
who holds the speed record? dracy69 Electric On-Road 880 08-22-2004 03:04 PM
New motor for my ele. I WANT SPEED (not gonna race) Smoke21 Rookie Zone 14 10-16-2003 11:40 PM
