Old 07-15-2011, 07:51 AM   #16
alcyon's Avatar
Kawada in japan does sell blank graphite sheets, 2.1mm thick...
http://kawada-alcyon.blogspot.com/
http://superturbooptimamidspecialzx-5.blogspot.com/
kawada sv10 alcyon 3-sanwa mx3x-orca vx v4.1 software-team powers 13.5 motor-turnigy 4200 shorty lipo-savox 1251 servo RIDE RE32
alcyon is offline   Reply With Quote
Old 07-15-2011, 08:04 AM   #17
The tub your planning on replacing looks like it has a bunch of CF stuff already...not sure you'll get much benefit.
I'm also curious to ask if the tub has integrated diff housings or if they can be removed to add to your project.
If they can be swapped, then your best bet is once you have the material (www.dragonplate.com is my favorite) you can just clamp the old tub to your sheet, mark/drill and mount the sheet so it doesn't move and then have at the cutting, grinding and shaping process.
I've also had good success with scanning a tub at full scale and then printing that on a decal sheet to give yourself a template to work around.
As for making tools, I've had good success with mounting a dremel router base attachment to a small table to make yourself a "router table". It has the option to remove the dremel from the base so you can hand grind if needed and gives anice flat area to hand manipulate the chassis template for consistent grinding.
Good luck with your endevour.
I wonder what rocket scientists say to their co-workers when one of them doesn't get it?
cowboySiR is offline   Reply With Quote
Old 07-15-2011, 08:15 AM   #18
diff housings come off the only thing that does not come off is the gearbox for the spurgear cover
bosco72 is offline   Reply With Quote
Old 04-07-2016, 01:47 PM   #19
1stPlaceAllDay's Avatar
im thinking of doing the sc5m ,, there is a carbon chassis available but i dont like the standoff posts..i want to just change the aluminum to carbon fiber...ive done this before..using just a dremel
clamp aluminum chassis to new carbon fiber sheet and use it as a template-jig. usually only takes a hour or more to do one. depending on the complexity of the cuts and holes
1stPlaceAllDay is offline   Reply With Quote
Old 04-07-2016, 06:02 PM   #20
Trader Rating: 47 (100%+)
A friend of mine cut this chassis for me. All counter sunk holes are done by the cnc machine as well. I can talk to him if any of you are interested.
v_squared is offline   Reply With Quote
HoBao Hyper 9E thread zJatoRad Electric Off-Road 4395 07-25-2017 04:36 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
Carbonfiber 1/8 buggy chassis? havatitan Electric Off-Road 10 02-24-2010 12:13 AM
Composite vs. Carbon Fiber Chassis. Pro/Con? vi3tishduy Electric On-Road 7 08-04-2005 08:31 AM
