Old 07-14-2011, 12:42 PM   #16
I mostly use a 4.5T (Speed Passion) and ESC boost. It maybe sounds insane, but with a good, smooth ESC (like the SP GT2.0 Pro) it is controllable - and FAST!
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 07-14-2011, 01:07 PM   #17
Thanks for the replies.
I'm currently running 13.5t boosted and I'd like to think I'm pretty consistant at my local track. Supposed to be trying 10.5 boosted this weekend and to be honest I really don't think there's going be any difference, I have already been quicker with my 13.5 than some 10.5 at my track.
Mod's are only 2 or 3 at the most laps quicker than 13.5t boosted at our track, but mod seems alot easier to set up with out all the boost, turbo etc which is why I went LRP speedo route no bloody laptop needed
I might just give my SP 5.5t a go in blinky mode.
S.A.W is offline   Reply With Quote
Old 07-14-2011, 06:09 PM   #18
CraigM's Avatar
Trader Rating: 34 (100%+)
Mod is a lot easier to get the right power for a track than the boosted spec classes. That's not to say that you shouldn't run timing on the ESC in mod, it just doesn't make as much difference having the perfect ESC settings in comparison to spec.
In general I think you'll find most top mod drivers prefer to run a lower wind with little or no boost compared to a milder wind with a lot of boost. I've read people saying mild winds with timing are easier to drive but I haven't found this to be true, not outdoors on medium sized tracks anyway. Anything more than a low level of boost on most tracks leads to lower consistency, that's what I've found anyway.
With that in mind I stick to 4t-5t, usually 5 works well on most tracks but once the straight gets up around 40-50m then usually a bit more power can be bolted in. If I had to have only one motor I'd own a 4.5
Sorry for the long reply, hope that helps...
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-14-2011, 08:51 PM   #19
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
This and answers like it are the ticket, I think. Good stuff
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 07-15-2011, 12:35 PM   #20
Tried a SP 5.5t today witha Lrp SS V2 zero boost geared at 8.0 then tried 7.5 = Slow didn't try gearing up anymore definatley needed some boost for the straight, it was slower than my 13.5t boosted
Old 07-15-2011, 06:13 PM   #21
Suspended
I don't know how long your track's straight is , but 7.5fdr is recommended for 4.5t motors with zero boost ! 5.5t motors can easily go as high as 6.8fdr with no boost !!!
bertrandsv87 is offline   Reply With Quote
Old 07-16-2011, 05:50 AM   #22
You will need boost with a SP 5.5, it will simply be soft without it. Most other 5.5's won't be much better. I run my Orion 5.5 with boost around 7.2FDR. Settings for a boosted 5.5 are not massively different to boosted 10.5.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
The reason for the lack of mod drivers... robk Electric On-Road 327 06-22-2009 05:23 PM
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
ROAR B/L motor Rules debate thread C_O_jones Electric On-Road 1080 01-21-2008 08:00 PM
DC Motor Sports Discussion Thread: Curtis Schlaht Team and Company Discussions 2010 11-28-2006 11:42 PM
12 turn motor limits...Your experience? Simon K Electric On-Road 50 07-11-2004 09:45 PM
