Old 12-20-2011, 05:30 PM   #46
Regional Moderator
CarbonJoe's Avatar
Originally Posted by xraydad View Post
Hi there, this is one for the guys on this thread using the 500000 wt oil rather than the gum in the diff. Very simply, how far do you fill the diff casing when running in stock classes - 21.5 & 13.5?.
I almost fill it. Add some, assemble the diff and try turning it. If it gets easier to turn after a few revolutions, you need to add more.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 12-21-2011, 08:04 AM   #47
M-Technic's Avatar
Trader Rating: 15 (100%+)
I added putty, closed the diff and rotated it to spread it around, reopened and added more. Probably did that 3 times until it was very full.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 12-21-2011, 08:29 AM   #48
ahpeq_ong's Avatar
front diff using putty and mix abit with silicone oil (correct me if im wrong)
or just using thicker gear oil such as 200k and above...
for rear diff...?
in my track,their using 500 to 1200...
i just want to know,what is the diff when using thicker oil at rear...?
thank guys...
ahpeq_ong is offline   Reply With Quote
Old 12-21-2011, 09:24 AM   #49
M-Technic's Avatar
for rear diff...?
thank guys...
Putty is considerably heavier than even 500,000cst oil.
Rear diff, 500cst-2,000cst depending on the track, tires, and conditions.
Old 12-22-2011, 02:58 AM   #50
ahpeq_ong's Avatar
so what is diff using thicker oil...?
thicker for high traction or low traction...?
Old 12-22-2011, 07:49 AM   #51
M-Technic's Avatar
Generally, thicker is for high traction.
Old 12-22-2011, 07:54 AM   #52
ahpeq_ong's Avatar
noted...
im playing 10.5t with boost...
mid traction...
any recommended?
Old 07-22-2014, 02:35 PM   #53
Need we change the putty after some runs? Or just for a log time after !!
Fabiano TKL is offline   Reply With Quote
Old 07-23-2014, 11:30 PM   #54
OttoKrosse's Avatar
Just bought a used tc6.2 that came with a front diff, it has 2.5 million weight oil in it based on the sellers comments to me. His advice was to use it on a high traction track, otherwise the spool may be a better way to go.
I've just set the car up with electronics and will give it some track time on Saturday, if I have anything to add I'll revisit this thread.
This space for rent.
Oo=00=oO
OttoKrosse is offline   Reply With Quote
Old 07-24-2014, 04:18 AM   #55
tc3team's Avatar
I tried 500,000 with foams and it gave a lot of steering, way too much to drive a consistent race.
I am on 50,000 now and its a comfortable amount.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
