Bit for a Twister Comm lathe >
Old 10-20-2004, 08:24 AM
tr6_guy's Avatar
Default Bit for a Twister Comm lathe
I recently purchased a used Twister Comm lathe and it arrived with a pretty dull carbide bit and a chipped diamond bit.
Does anyone know where the best place to purchase a new carbide bit for this lathe would be?
I've never used a comm lathe before so, I want to get a carbide bit for learning purposes before I spring for a nice new diamond bit.
tr6_guy is offline
Old 10-20-2004, 08:41 AM
Jack Smash's Avatar
Trader Rating: 33 (100%+)
You don't need a new carbide bit. You need a diamond file to sharpen yours.
www.mcmaster.com p/n 8168a13 coarse $19.22
or call 562-692-5911
you might want to pick up a couple of bits too.
p/n 3367a121 $3.42
You will need the file to put a tip on the bit, they come with the correct angles but the tip is rounded.
Jack Smash is offline
Old 10-20-2004, 08:46 AM
howard hudson's Avatar
Default Re: Bit for a Twister Comm lathe
If I remember correctly the twister lathe cuts from the right to left. There is a guy on ebay that sells Diamond bit's for 49.00 I belive you would get a 4AR part # I have a xipp lathe and it cuts from right to left and uses the 4AL
howard hudson is offline
Old 10-20-2004, 08:53 AM
tr6_guy's Avatar
Thanks for the help!
tr6_guy is offline
Old 10-20-2004, 09:58 AM
kufman's Avatar
Hey Jack,
Why the course file and not the fine grit one?
kufman is offline
Old 10-20-2004, 10:09 AM
Jack Smash's Avatar
Makes it easier to get a the tip onto a new bit. From what I hear, not much difference in the point with either file.
Old 10-20-2004, 10:59 AM
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
A bench top grinder with a "green" wheel does wonders too. Made specifically for sharpening carbide bits.
Wayne
sg1 is offline
