tire stick stuff >
tire stick stuff
tire stick stuff
Old 10-19-2004, 07:38 PM
Default tire stick stuff
what tires should u dope up if u are running on a flat oval and then on a banked oval? i did all 4 on my tc3 and it seems to slow way down when i went into a turn. thanks
Aadolf is offline
Old 10-23-2004, 02:43 PM
bump does anyone know the answer or have any opinions?
Aadolf is offline
Old 10-23-2004, 03:59 PM
raving-monkey's Avatar
probably because your current setup was to soft...if you put additive on to it will take away even more corner speed.
try stiffening the whole car up by moving the shocks outwards on the shock tower, or changing the springs...or something.
raving-monkey is offline
