HPI sprint 2 drift set up >
Like Tree1Likes
  • 1 Post By mnr3.3
Old 07-11-2011, 11:35 AM
Default HPI sprint 2 drift set up
Greetings,
I was wondering if anyone can give me some drift set up info for my sprint 2. I am planning to install the sway bar but not sure which one will fit...thanks
boudin4evr likes this.
mnr3.3 is offline
Old 07-11-2011, 11:50 AM
Registered User
It drifts just fine stock but what I do recommend upgrading is the spur gear mount. When I changed motors on mine, the first thing that happened was the increased torque chewed it up. I also changed the front dog bones to the universal ones because you'll notice soon enough that when the knuckles start popping off, you'll probably lose a dog bone or two. It doesn't really happen to the rear so I didn't change those. Other than that, I wouldn't really change much on the car. The less you spend on it, the more money you'll have to buy a better chassis.
And FYI, I'm not an "expert" drifter or anything. I'm just a beginner but I wanted to share with you my experience so far hoping maybe you could benefit from it.
Seanzky is offline
Old 07-11-2011, 12:15 PM
Robotech's Avatar
Old off road tip that may help if you're limited on funds...paint your dogbones a bright color like neon-orange. Before CVDs and Universals this was a huge problem in off road rc and guys use to do this so when they threw a bone they could have a much easier time finding it.
Robotech is offline
Old 07-11-2011, 12:18 PM
Do not get a swaybar it will make things more difficult. Get a front one way, a locked rear diff (spool) and a fast servo, some drift tires and your all set.
O and metal spur gear mount like was mentioned, there only like $5.
Jdmpurest is offline
Old 07-11-2011, 12:55 PM
Registered User
Ah! Good tip. I should have done this, but it's probably better that I upgraded anyway because mine was getting chewed up.
I forgot to add that I also upgraded my servo to a 645MG. So, OP, think about doing that too.
Seanzky is offline
Old 07-11-2011, 01:13 PM
Yea try to get the fastest servo you can for your budget. Under the specs look for something as close as possible to .10 at 6V. Dont pay attention to High torque, you want High speed. Try to get it Digital if you can as well, depending on what transmitter your using it will allow you to run in a higher response mode like Futaba's. I have a .010 at 6v servo running in HPM mode on a Futaba FASST TRX. Its not a big deal if you cant get one digital but if the price is good dont hesitate.
Old 07-11-2011, 01:41 PM
Most important thing for drifting by far is good response, both throtle and steering. Otherwise no matter how good your setup is you wont do much
*coming from a guy that drifts a old nitro rs4 with some of the slowest servos known to mankind.
kb525 is offline
Old 07-11-2011, 02:59 PM
Yea I was thinking countersteer drifting, if hes just doing a regular balanced AWD setup then a fast servo doesnt matter, like in your case.
Old 07-11-2011, 03:10 PM
in my case a faster servo would help. Honestly it is always of help but only if you know how to use it.
kb525 is offline
Old 07-12-2011, 08:00 AM
Thank you all for the swift reply, I am indeed very grateful...
What about the set up on the suspension, camber, toe in or out, droop and balancing, tweaking and set up board....I read about those stuffs and found it quite interesting...
Bought the car used and it 'drift' just want to make it more manageable without spending so much...Thanks again all for the recommendation....
mnr3.3 is offline
Old 07-12-2011, 09:58 AM
i just learned from onroad tc people. i would read set up guides from those guys then i would know how to dial in more understeer or oversteer. there is really no cookie cutter settings to give you every set up is different. tires is a pretty big thing your setup will be very different based on tires. like i run Yokomo zero 1R tires for carpet and asphalt. zero1's have a inner rubber lip that allow you to get more grip out of the tire the more negative camber you dial in. with Tdrifts more neg camber reduces grip. CS drifting requires completly different. So my advice is practice with the car then figure out what makes it hard to drive like if it spins out too easy on transisitions go read a setup guide on how to tune in more rear wheel grip. thats an example. thats how i learned drift setup.
There's also this guide on DRCCentral.
http://www.drccentral.com/forums/ind...=0#entry155508
