Old 07-10-2011, 12:04 AM   #1
BBP
Default Have a problem with cornering, pls HELP
Hi guys, I'm running a TA 05 VII R with tamiya brushless 10,5T. Have problem with cornering, everytime i make a turn, it is so wide open. Can you guys help me?
BBP is offline   Reply With Quote
Old 07-10-2011, 01:42 AM   #2
Radio Active's Avatar
When approaching a corner, back off the throttle a little bit, and then turn. Try that and tell us how you go.
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is offline   Reply With Quote
Old 07-10-2011, 03:44 AM   #3
They are so many things that can be the reason, but the obvious is what Radio Active said, in electrics you need to slow down before the bend, keep a constant speed during the turn and accelerate coming out to the next bend, something IC drivers find hard to do, as they brake later and accelerate in the bend.
Then your car setup, have a look through the net to find a setup sheet for your model, I am not familiar with Tamiya, never had one!
Make sure that your car is well built as explain in your manual, I have seen cars with right to left suspension parts on the wrong side before.
Put a little bit more toe in on the rear, check that suspensions are not too soft/hard etc...
You can start with this, it should help, and remember, there is no point to be the fastest on a straight line if you cannot take a bend and come off track at every turn.
Good racing
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 07-10-2011, 04:37 AM   #4
Foxxrocket's Avatar
Check the servo travel. Make sure that the horn is moving as far as it can go, without conflicting with the steering rack.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Mugen MBX5R rear end breaking loose, Help Pls! pracy Nitro Off-Road 14 05-20-2008 06:46 PM
