Old 07-17-2011, 04:14 AM   #91
Suspended
Most esc do a double tap for reverse, IE, when you hit reverse the first time it brakes, 2nd time it goes backwards. Be sure to use definite actions for brakes or you end up going backwards when you dont want to. If you have the choice to, use no reverse at all in the esc.
RogerDaShrubber is offline   Reply With Quote
Old 07-17-2011, 05:56 AM   #92
I tried the double tap, it doesnt always work. It feels quite random and when it does work, it goes backwards very fast.
Also, is it normal for the battery to last for about 20min?
soldier16 is offline   Reply With Quote
Old 07-17-2011, 12:11 PM   #93
Never mind, i figured it out. I was using it whilst the thrust level was set to zero. When i increased it a little bit, i was able to go backwards in the normal mode using the double tap.
Old 07-20-2011, 03:19 PM   #94
20 minutes for a 1800 is descent
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
XXX-CR Thread Matt Howard Electric Off-Road 5778 04-03-2017 01:45 PM
All abt kyosho ZX5 post here SuperEk4 Singapore R/C Racers 775 01-04-2010 10:36 PM
Why cant the MM 7700 run 3s? Fatstogey Electric Off-Road 34 05-24-2009 12:26 PM
It's time for race tracks&directors to step up Juan Aveytia Electric On-Road 19 11-26-2006 08:09 AM
