Old 07-09-2011, 12:28 AM   #1
Maxthepersonz's Avatar
Trader Rating: 20 (100%+)
Default How do you attach the wing? Protoform Mazda 6
I used to run on road forever ago and never actually attached a wing before so basically this is my first on road body with a wing. Very noob question just looking for the simple awnser!
-Max
Serpent Spyder SRX-2 asap...
Airtronics M12...
MARCCA Racing, Trackside, Performance Hobby Center...
Maxthepersonz is offline   Reply With Quote
Old 07-09-2011, 12:31 AM   #2
rc_square24's Avatar
-Max
There should be a pair of nuts and screws, make holes on the body and wing dimples and attach.
rc_square24 is offline   Reply With Quote
Old 07-09-2011, 12:41 AM   #3
Suspended
-Max
I always position mine using the rear most body holes and front most wing holes because im a noob and i am looking for all the rear grip i can get, further back its positioned being more down force is the general principle.
RogerDaShrubber is offline   Reply With Quote
Old 07-09-2011, 01:15 AM   #4
roger999's Avatar
Just remember to use something to shim your screws under screw head, like piece of lexan or plastic shim.
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 07-09-2011, 01:25 AM   #5
Sweet thanks guys. What if I dont have the hardware? where can I get it?
Airtronics M12...
Old 07-09-2011, 02:24 AM   #6
Hobby shop?
Protoform screws are a bit small on the head and can tear easily / flex on wing. I usually use a countersunk 3mm screw with cone washer for larger area.
Old 07-09-2011, 04:40 AM   #7
Default wing
spot of shoo goo on each side of wing simples
MB Models Leeds,RC4LESS,Troy McKune
V-DEZIGN CR5 ,LRP SXX, CRC cells,
tellan is offline   Reply With Quote
Old 07-10-2011, 03:32 AM   #8
^Very good advice here. I lost a race before for not doing that, wing popped off one side... couldnt even make the car trail straight when braking heavy before corner.
Tastetickles is offline   Reply With Quote
