Proto LTC-R and MazdaSpeed6 >
Old 07-07-2011, 12:28 AM
Geberit's Avatar
Default Proto LTC-R and MazdaSpeed6
I see the most driver are using this two.
So the question is when to use which (track layout) or is it just what you prefer?
Regards, Lojz
Geberit is offline
Old 07-07-2011, 02:05 AM
RL.2002's Avatar
Regards, Lojz
for me the ltc-r is for outdoor asphalt n the mazda6 is for carpet
RL.2002 is offline
Old 07-07-2011, 04:19 AM
+1
starrx is offline
Old 07-07-2011, 05:23 AM
chubbspeterson's Avatar
Originally Posted by starrx View Post
+1
-1
It's setup, I run the both on carpet. The LTCR keeps my setup more planted in the rear, in fact I can notice a change in the car just by mounting the front of the body lower or higher in the front. My personal results are
LTCR- more traction in the rear
Speed 6- more steering, loose rear
If the track grip will give me more traction, I will run the Speed 6, if not, it's the LTCR.
chubbspeterson is offline
Old 07-07-2011, 06:28 AM
thats odd I find them the opposite to what you have just said and the majority of drivers I know find ltcr looser at the rear
ltcr more direct sharper steering but washes out midcorner
speed 6 smoother more consistent steering
any one else
CHeers RC
prodriver is offline
Old 07-07-2011, 06:33 AM
Dane's Avatar
Trader Rating: 25 (100%+)
any one else
CHeers RC
Yes. LTCR is more aggressive while MazdaSpeed6 is more smooth. I think due to the nature of the surfaces, you tend to see more MS6 on carpet and more LTCR on asphalt. But that's not set in stone by any means.
Dane is offline
Old 07-07-2011, 07:42 AM
pakk's Avatar
Trader Rating: 80 (100%+)
Originally Posted by chubbspeterson View Post
-1
I find this to be the exact opposite.
pakk is offline
pakk's Avatar
I heard the p37 is somewhere in the middle. I need to try one.
pakk is offline
Old 07-07-2011, 08:00 AM
artwork's Avatar
Trader Rating: 76 (100%+)
The LTC-R is designed to be a bit more aggressive then the speed6, and feels exactly this way on both carpet and paved surfaces. for my driving style I prefer the LTC-R on both surfaces. I find that the LTC-R initiates the corner a lot better and is better for tighter more technical tracks and the speed 6 is better for flowing more high speed tracks. Some cars are naturally more aggressive then other regardless of the setup, if I was running a Tamiya or Hotbodies I would lean towards the speed 6, but if I was running an Xray or TC6 I would probably always run the LTC-R.
The best thing to do is buy or barrow both and run them back to back to see which one you like the best. The differences on the track are subtle, but you should be able to feel a difference.
artwork is offline
Old 07-07-2011, 08:09 AM
Fred Hubbard's Avatar
LTC-R = Generates a bit more initial steering
P37-R = Good balance of entry and exit steering
Speed 6 = Less initial but more mid/exit steering
I recommend always running the lightweight versions of these bodies because they produce faster lap times than the regular weight versions.
Fred Hubbard is offline
Old 07-07-2011, 08:31 AM
pakk's Avatar
+1 to trying out bodies. It took me a while to get a good feel for what I like. When it came down to it, the lap times were more consistant with the speed6 and the car was much easier to drive for me. Being that with my photon, I find myself dialing out a lot of steering, it only makes sense.
It's too bad that I read somewhere that protoform did not send the speed6 for it renewal. So last I heard, it's not roar legal. I don't really care if it's roar legal or not, I just hope they don't stop making them.
--pakk
pakk is offline
Old 07-07-2011, 08:35 AM
--pakk
No worries it's back on the approved body list. It was just a timing mix up
Old 07-07-2011, 09:13 AM
pakk's Avatar
Best news I've heard in a while. Thanks!
pakk is offline
Old 07-07-2011, 01:16 PM
nf_ekt's Avatar
Trader Rating: 115 (100%+)
any one else
CHeers RC
Same for me, though I've only run asphalt to date. The Mazda has always been easy and consistent to run in my opinion.
nf_ekt is offline
Old 07-07-2011, 02:24 PM
+1
I can't tell how and why the lightweight bodies are different (they are thinner, duuuh), but they just drive better!
Nilks is offline
