Old 05-18-2002, 01:00 AM   #1
TRF-Powered's Avatar
Default Schottey Diode
Hi,
I got a question on Schottey diode. I have a Ko VFS ESC, and the schottey diode is borken. Do I have to buy the KO schottey diode for it? or I can use any brand of schottey diode?
some people I met at tracks told me that I might not even need a schottey diode. They had various brand of ESC, and some of them says that even without the schottey diode, their ESC is working fine. Is that true?
Thanks for any input.
TRF-Powered is offline   Reply With Quote
Old 05-18-2002, 01:14 AM   #2
dtm
dtm's Avatar
Send a message via ICQ to dtm
You can use any Schottey diode....it is better to have them installed. Stops feedback into the ESC when you are off throttle....you may be able to run for months with no problems....but you only have to burn out one expensive ESC to make yourself look really stupid for the sake of such a cheap component!!! Some ESC already have the schottey inside the unit (Tekin).
dtm is offline   Reply With Quote
Old 05-18-2002, 01:32 AM   #3
Wilfred's Avatar
By the way guys, it schottky not schottey. You can use ordinary rectifier diodes, hi amp rating the better.
Wilfred is offline   Reply With Quote
Old 05-18-2002, 02:45 AM   #4
dtm
dtm's Avatar
Ooops......I just copied what TRF wrote!! Thanks for the correction!!!!!!!!!!!!
Old 05-18-2002, 01:25 PM   #5
jcr
what's the specs on this diode anyways?
jcr is offline   Reply With Quote
Old 05-19-2002, 08:35 PM   #6
IceBerG71's Avatar
so if the ESc comes with the diode, and we solder another in, is it ok to solder anothe rextra ones on the motor??
IceBerG71 is offline   Reply With Quote
Old 05-20-2002, 07:46 PM   #7
Avink1's Avatar
Send a message via AIM to Avink1
Even if the esc has a built in schottey diode you should still use an external one on the motor. Don't use more than one external diode as this may cause negative affects.
Avink1 is offline   Reply With Quote
Old 05-20-2002, 08:01 PM   #8
Manticore's Avatar
R/C Tech Charter Subscriber
solder them in paralle will increase AMP tolerance.
Usually you dont need that many with onroad but you might need more then 1 on motor off road as you much more brake.
Manticore is offline   Reply With Quote
Old 05-20-2002, 10:22 PM   #9
IceBerG71's Avatar
so the diode is only meant for a forward//brake esc.... not for forward//reserve type of esc....
what will be the effects with and without the diode on the performance of the car?
Old 05-21-2002, 08:59 AM   #10
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
Has anyone seen KO's diode? It looks different with its boxy features. Quite bigger though.
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 05-21-2002, 04:32 PM   #11
Ko's diode isn't that good. I had one with my VFS ESC from Ko. the diode came off it's post during the soldering procedure to the motor.
I think that's why KO has developed a new super diode which suppose to give you more punch fromt he ESC...
Old 05-21-2002, 07:29 PM   #12
Manticore's Avatar
diode is not to give punch, it is to protect your ESC.
Old 05-21-2002, 08:48 PM   #13
I know diode is to protect the ESC. However, that's what Koprop's site says, the new diode will protect the ESC, plus give you more punch out of it.
Believe it or not... that's what Ko is claiming..
Old 05-21-2002, 09:22 PM   #14
Manticore's Avatar
then there must be something wrong with their ESC.....
Old 05-21-2002, 09:52 PM   #15
IceBerG71's Avatar
i also heard that diode is to protect the esc, claims from LRP.
whether it will give more punch, i am not sure. anyone can confirm or prove it??? i thought only batteries will decide the punch of the car??
Correct me if I am wrong.
Schottky Diode Martinst Rookie Zone 7 03-17-2008 05:27 PM
diode harddrive Electric On-Road 10 02-27-2006 10:40 PM
Schottky diode? 4ou Rookie Zone 6 08-27-2005 03:28 PM
schottky diode help JL Electric On-Road 3 08-27-2005 10:36 AM
Schottky diode for ESC danjoy25 Australian Racing 13 07-14-2005 12:12 AM
