Electric On-Road COST
#16
Jorge, have you done any r/c car racing before?
Also, do you have any r/c on-road track or tracks nearby? Best thing to do is find out what's available around your area. You can have lots of fun racing r/c cars without burning a hole in your wallet.
At our hobby shop, we started a simple parking lot track with dots and cones. Spec class is M chassis from Tamiya. The 1/10 sedan class is pretty much run what you got. So far, most of employees and customers enjoy running the M chassis more. Finally, there are 4 regulars show up to demonstrate some side by side drifting actions.
Just remember the key is to have fun.
Finding a club that is near by is the best advice anyone can give a newbie. It is at the club level that you are going to learn all aspects of the sport, meet new people, have fun and hone your skills. I so look forward to club race day, its the best day of the fortnight.
#17
That out of the way, Roger is spot on here. Getting to know what they race in your neck of the woods is important. Would stink to get a nitro car and find out that there really is no nitro racing in your area.
Find something that fits your budget, has good parts availability at your local hobby shop, can be raced at your local track in an established class, and most of all...have fun.
#18
Nitro is tough, I recommend starting with electric, unless your local track only does nitro. and def start off with an RTR if you are going the Nitro route.
With Nitro I have NEVER came out to a track, put my car on the starter box, hit it and it started.. Always an issue, so much goes into starting the car and then when you go around the track you need to adjust it to your liking but every time I wanted to adjust it the car would turn off and then I couldn't get it started AHHHHH Had to sell my 1/8 on road and go to electric.
With electric as long as your batts are charged you just hit ON and then worry about car setup.
The right of passage to Nitro is Electric.
For electric if you want to get going with a nice setup for cheap start right here on the forums!
used Futaba 3PMx with receiver - $100
used Savox 1251 servo - $50
Used roller tc3, xray t2 007, 08 around $150
Wheels with tires - $20
new Lipo from hobby king $30
new Venom Charger - $90
New body, paint, scissors... $40
used Motor and ESC - $100
You can have a nice electric setup to start with for under $600
But, hey, what do I know.....
#19
My local club is mostly nitro, but i found this car to be way too fast for my abilities, so i changed to 17.5T electric and have been slowly gearing up as my skills improve, it won't be too long now till i can handle the pace of the nitro car. From what i have learned, its better to turn consistent slow laps working up to a faster setup than having the fast setup and not being able to control the power and spending all your time being marshaled.
#21
(BTW, your symptoms sound like the product of a too lean top speed needle...it would run, overheat causing it to shut down, then could not restart until it cooled off. It's very common. Obviously I could be wrong since I'm just going by what you posted but that's what it SOUNDS like.)
I did not suggest going electric first because I don't know the OPs background. He could have ran 1/8th scale nitro off-road for 15 years for all I know and tunning an engine is a no brainer for him.
But Onetrade and Roger both make good points, usually folks go with electric first and nitro later once they learn the basics of on-road with a less troublesome electric car.
#22
i've raced both nitro and electric. by far nitro is way more expensive. the maintenance for a nitro tc is way more in cost and wrenching. i don't want to discourage anyone from nitro, but you gotta have deep pockets.
