Old 07-04-2011, 08:30 PM   #1
Default Tamiya TT-01 Q & A
I created this thread for not only me, but for everyone that's new to the hobby to ask Questions having to do with the Tamiya TT-01 and recieve Answers, suggestions anything helpful. I'm new to this Hobby and I plan on Getting a TT-01 so please exspect several questions from me .
Notice: Only Newbies may ask Questions...Knowing that this forum is only for Newbies to learn and understand there car.
Wavey_King is offline   Reply With Quote
Old 07-04-2011, 08:33 PM   #2
This Forums' First Question: Knowing that LiPO batteries are better, what mAh should I get to get long-lasting run-time and more power; something the chassis could handle.
Old 07-04-2011, 09:07 PM   #3
A battery is a battery is a battery.....the mah rating is the size of the gas tank. The larger the number, the bigger the tank. A larger tank/battery will weigh more but give you more run time. Go Big or Go Home!!!!!!
The S rating [2s, 3s, 6s] is the power/voltage.
Just be sure the electronics can handle the power.
2s is about all the TT-01 will handle, given it's limitations.
Goals Achieved....Running at the End and Not Dead Last.
mooby64 is offline   Reply With Quote
Old 07-04-2011, 09:13 PM   #4
Thanks..So any mAh Size? If so Ill get a 3000-5000mah
Old 07-04-2011, 09:59 PM   #5
This thread will help answer any questions on the TT-01.
http://www.rctech.net/forum/electric...-01-forum.html
x3inchesx is offline   Reply With Quote
Old 07-05-2011, 11:42 AM   #6
does any one here race tt-01e against xrays&tc6's in gta/vta ?
if so are you always last?
urban is offline   Reply With Quote
Old 07-05-2011, 04:38 PM   #7
Dali's Avatar
One of the first mods you might want to consider is replacing all the shitty plastic bearings with proper ball bearings. A set only cost me around 10 on ebay.... much smoother, less friction - more speed - don't forget to grease them!
Xray T3 2011, Tekin RS Pro with 13.5 Redline (Brushless), SAVOX 1251 Servo, Team Orion 5400 Carbon LiPo, Sanwa Exzes-X Radio System
Dali is offline   Reply With Quote
Old 07-05-2011, 09:55 PM   #8
Well, as I said, I'm a newbie with these type of things...So I might need help with the whole process.
Old 07-06-2011, 03:07 AM   #9
Good luck.
caaraa is offline   Reply With Quote
Old 07-06-2011, 03:17 AM   #10
RUNNINONMT's Avatar
I use my tt-01 for drifting and im having trouble with it transitioning in the switchback it starts to push can anybody help me with this. thanks....
RUNNINONMT is offline   Reply With Quote
Old 07-07-2011, 04:04 PM   #11
MostWanted4TEC's Avatar
Send a message via AIM to MostWanted4TEC
There's another forum if your interested called Tamiya TT-01 that has a lot of advanced info floating around the electric tech somewhere. I've been around the TT-01 for awhile but hopefully someone can help and this will hopefully be beneficial to everyone reading.
Got a DE10 duratrax sec with a 17.5 ballistic 25p 55s. The motor is winding out and the sec is averaging 24mph. Is that normal or could using non Tamiya gears be the cause like in few models? Pitch is all the same just after market everything. Thanks everyone!
Tamiya TT-02|Factory RC10R5|TC
The way to gain a good reputation, is to endeavor to be what you desire to appear. - Socrates
MostWanted4TEC is offline   Reply With Quote
Old 07-12-2011, 07:56 AM   #12
If you are using oil shocks, TRF's or CVA's, run a hard spring in rear Tamiya blues and a red spring up front. The flourescent red spring is a little softer than the TRF white spring (think the white paint stiffens it up a little).
If your camber is set to 0 degrees all round then add a degree of negative camber on the rear to give the front more grip.
mr lee is offline   Reply With Quote
Old 07-12-2011, 07:58 AM   #13
Some useful info for beginners that want to know the difference between the old and new type E. All new parts are compatible with old ones.
http://www.tamiyausa.com/articles/fe...article-id=415
Old 07-12-2011, 07:42 PM   #14
mon
Can I reverse the position of the upper and lower rear arm of my TT01 ? What effect would it make ?
mon is offline   Reply With Quote
Old 07-13-2011, 06:12 AM   #15
If I understand you correctly you are wanting to flip them over 180 degrees, correct?
If so then you will be shortening the wheel base. This is required for certain Tamiya bodies such as the Porsche 911 or Toyota MRS.
