Old 10-17-2004, 06:37 AM   #1
Default Cooling batteries while charging
It is advisable to cool batteries while charging them? I'm running stock, 3300 6 cell packs at 6 amps. Should they be kept cool while charging with a small fan underneath or should they just be kept off the surface with a small wire rack so normal room temp can circulate around the pack?
Just wondering. I use the Novak tray for conditinig the cells. and dump them at 20 amps before traying them.
visit Hurricane Motorsports: www.teamhurricane.net | RCAmerica www.RCAmerica.com | HUDY | JACO
bigdog xxx-s is offline   Reply With Quote
Old 10-17-2004, 06:39 AM   #2
JDXray's Avatar
Send a message via AIM to JDXray
I think theres many ways to do what you want with your packs. I for one just charge them up and let them cool down and run them or re-peak them.
Others might tell you to have a fan on them while charging.
JDXray is offline   Reply With Quote
Old 10-17-2004, 06:46 AM   #3
pink pac man's Avatar
i cool them when i charge them cos if i dont then i cant even pick them up there just to hot and im only charging at 3 amps
pink pac man is offline   Reply With Quote
Old 10-17-2004, 06:50 AM   #4
Johnny J's Avatar
Whats your Cut off theshold Pink Pac man? Too hot to touch at 3 amps is crazy.
I charge mine at 6 amps with .5mv cut off and they are warm.
Johnny J is offline   Reply With Quote
Old 10-17-2004, 06:55 AM   #5
i dont know the cutoff its a shity $60 charger and the cutoff is set at sumthing...........ill chek the instrutions.....back in 5
Old 10-17-2004, 07:01 AM   #6
JDXray's Avatar
ya shouldnt get that hot, i charge at 6amp at 35mv and its warm/hot but i can still hold them.
Old 10-17-2004, 07:05 AM   #7
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
I have an old 12v 80mm PC Power Supply fan that I use to keep air cirulating over the cells when charging and re-peaking them, makes quite a large difference if you ask me, they are noticably cooler when I have used the fans than when I havent used the fans...
I use an old 1700mAh NICD to power them, it lasts 2 meetings before it needs to be topped up again. I'll be modifying my fan setup to run from my 12v power supply soon, get a little more power from the fan setups.
Might even get some of the LED light 120mm fans for my new setup
Im planning how to temporarily attach heatsinks to the side of the cells when they're being charged, so long as the heatsink is only touching each individual battery bar there shouldnt be any problem with shorting out Still thinking about that idea, but hopefully it will drag the heat out of the cells..
v0rtex is offline   Reply With Quote
Old 10-17-2004, 07:08 AM   #8
it says it has a reliable battery full detection and charge termination using voltage monitor -^v termination [negative delta peak] additional safty timer and optional temp sensing cut-off
-automatic pulsed trickle charge after termination
-protected againt short circut/reverse polarity/and overload
-presice charge current range 100ma-4000ma
the batts perform flawlesly and after i race they seem cooler than they were when i charged them
Old 10-17-2004, 07:09 AM   #9
Matt Howard's Avatar
This is a VERY bad thing to do to your packs, The GP's are supposed to be hot before you run them. If you have a fan on them the outside will be cool while the insides cook. Every battery matcher that I've talked to said this is a bad idea.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-17-2004, 07:11 AM   #10
JDXray's Avatar
There you go, so you shouldnt use the fan. lol And thats the reason why i do not use the fan.
Old 10-17-2004, 07:11 AM   #11
picco007's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
135 degrees or so.....and you should be good.
EA Motorsports
picco007 is offline   Reply With Quote
Old 10-17-2004, 07:12 AM   #12
ive bin told that and i try to follow it but my cells get to hot to leave un fanned
Old 10-17-2004, 07:12 AM   #13
JDXray's Avatar
just seems so wrong that your packs are that hot. you should find out why.
Old 10-17-2004, 07:14 AM   #14
ALBERTO's Avatar
Trader Rating: 23 (96%+)
Send a message via AIM to ALBERTO Send a message via Yahoo to ALBERTO
I was under the assumption that use a fan while charging can cause flase peaking . I was also told that you want ya batteries to be worm ( not hot ) this allowes for a better charge. So on that note i charge my battereis and then put a fan on them . When I discharge I always have a fan on them If ya batteries are hot at a 3 amp charge ya peak has got to be way too high, anyway thats just my opinion
still fishing
ALBERTO is offline   Reply With Quote
Old 10-17-2004, 07:15 AM   #15
BTW, is that 135 degrees F or C?
Cooling Batts While Charging Potential World Electric On-Road 18 06-20-2006 08:41 AM
Cooling batteries Capone_GR Electric On-Road 30 04-27-2005 11:20 PM
Cooling Fans under batteries Kennedy Australian Racing 2 08-28-2003 03:29 AM
Cooling Batteries While Charging Calvin Ng Electric On-Road 38 08-27-2003 02:48 PM
Charging UMH Batteries Zuffy Electric On-Road 1 08-24-2002 11:08 PM
