Old 10-17-2004, 07:15 AM   #16
picco007's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Originally posted by JDXray
just seems so wrong that your packs are that hot. you should find out why.
JDXray,
He said something about a 60 dollar charger. I don't think he has a voltage threshold cutoff option. (i think)
I would be that is the problem.....
Pink Pac Man,
What charger are you using?
EA Motorsports
picco007 is offline   Reply With Quote
Old 10-17-2004, 07:16 AM   #17
Matt Howard's Avatar
Originally posted by pink pac man
ive bin told that and i try to follow it but my cells get to hot to leave un fanned
what kind of voltage cutoff are you using? a cutoff of between .03 and .04 is what you should be looking for. Any higher than that and your cells will get hot even charging at 3 amps
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-17-2004, 07:16 AM   #18
JDXray's Avatar
Send a message via AIM to JDXray
Originally posted by v0rtex
BTW, is that 135 degrees F or C?
Farenheit. in celcius that would be over boiling point... (212*F+/100*C+)
JDXray is offline   Reply With Quote
Old 10-17-2004, 07:16 AM   #19
picco007's Avatar
F
EA Motorsports
Old 10-17-2004, 07:17 AM   #20
pink pac man's Avatar
i have a friend that charges before the race[540] and im goin to ask if i can borrow his pulsar im 100% sure my charger is fudged cos i cant use this crap charger anmore ill kill my batteries but a cdc ver 6.0 for chrismas should fix this charger problem...............................ill record the heat of my cells next race metting and report back to you guys i hope its not more than 135 deg
pink pac man is offline   Reply With Quote
Old 10-17-2004, 07:19 AM   #21
Originally posted by picco007
JDXray,
Pink Pac Man,
man you guys post fast
ansmann
www.ansmann.de
Old 10-17-2004, 07:21 AM   #22
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
Go the CDC. I upgraded to one just a few weeks ago, and I noticed the improvement on the track... Not to mention you can see how many mAh the charger has pumped into your cells, you can discharge, charge at up to 7amps and even re-peak (or boost, as the CDC calls it..)
Oh yeah,. whats with the pink? :/
v0rtex is offline   Reply With Quote
Old 10-17-2004, 07:25 AM   #23
Originally posted by ALBERTO
I was under the assumption that use a fan while charging can cause flase peaking .
Makes sense to me, and explains something i saw today... Last weekend I changed all my packs as I always do for the weekends racing, and one of them (a GP3300, 6 cells) took over 4000mAh, I wasnt using any fans.
Today, I charged that same pack using the same peak detect settings and at the same charge rate (amps) settings, and it stopped at 3200mAh. I used my fans on this pack.
Interesting, indeed. May be better to cool them naturally by the looks..
Old 10-17-2004, 07:26 AM   #24
the pink is a trademark pink cars/bulkheads/bodies etc............included a pic of the @#@#$%$^%& charger
Old 10-17-2004, 07:29 AM   #25
Pink, all I can say is CDC ASAP!
Old 10-17-2004, 07:30 AM   #26
ditto my friend ditto
Old 10-17-2004, 07:39 AM   #27
Trader Rating: 70 (100%+)
Send a message via AIM to TexRacer
Note=You do NOT wanna run a fan on your packs ever unless something happens and you overcharge a pack.
You will loose MAH,Voltage and will raise the IR if you use a fan while charging.Major Performance loss and a chance to really hurt the cell.
PinkPacMan-Your not doing anything wrong.THE CHARGER is.
You guys have CDC over there and we have Integy(Same thing pretty much).
You can take a GP3300 pack and charge it at 6.0amps on the 16x3,16x4 version which is suppose to SELF detect voltage threshold and the pack will come off VERY hot.
You can take that same pack and charge it 6 amps on a 16x5,16x7,or a 16x9 and adjust it to 5mv/c-40mv/p (6 cell) and it wont be as hot.It's ALL about voltage threshold or Peak detection.
PinkPacMan-The saddest thing I see is guys buying $45.00-70.00 packs and then using a $40.00 chargers.
As soon as you possibly can upgrade your charger.
Since you have the charger you have USE A FAN.It's better to loose a lil performance than to overheat the pack.
BONUS- Being those new hand held temp guns are $25.00 it's smart to grab one even if running electric.
Optimum Temp is 120F-130F.If it's getting hotter than this(Depending on surroundings) then you can LOWER your threshold setting from 5mv/c or .05 to 3mv/c or .03
I hope this helps out guys.
*****Look me up on Ebay. I will have alot of stuff going up as 7/7/2016. User name is Dalracer.**** This is going to be a BIG ONE!!!!!!
Just wanted to say Thanks to RcTech for all these years of Great Information.
TexRacer is offline   Reply With Quote
Old 10-17-2004, 07:45 AM   #28
Default every1
thanks for the info i will never use this charger again......................thats if i can borrow a charger from mates [garanteed]
Old 10-17-2004, 07:55 AM   #29
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
the CDC is worth the money. Mine is just over a year old and it has been the desire of many of the guys at the track. Although I did just get the GM GMVIS Commander and this charger is not for the timid and not to be bought by the rookie racer. It is now my favorite charger.............but I still love my CDC and won't part with it. If you can only afford a lower cost charger than check everyone's favorite auction site. That is were I got my CDC for $60USD
Hope this helps
Stephen<><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 10-17-2004, 08:04 AM   #30
Hope this helps
Stephen<><
The GMVIS will possibly be my next charger, I need to be able to program my SX9 somehow! Otherwise it'l be a CDC.
Cooling Batts While Charging Potential World Electric On-Road 18 06-20-2006 08:41 AM
Cooling batteries Capone_GR Electric On-Road 30 04-27-2005 11:20 PM
Cooling Fans under batteries Kennedy Australian Racing 2 08-28-2003 03:29 AM
Cooling Batteries While Charging Calvin Ng Electric On-Road 38 08-27-2003 02:48 PM
Charging UMH Batteries Zuffy Electric On-Road 1 08-24-2002 11:08 PM
