Old 10-16-2004, 06:57 PM   #1
crACkeD ChaSsiS's Avatar
Send a message via AIM to crACkeD ChaSsiS Send a message via Yahoo to crACkeD ChaSsiS
Default Tc3 Website?the Guy Shows And Tells U How To Mahcine The TC3s Chassis??
ny1 no the website were the guy tells and dispalys pictures on how u move the batts closer to the centerline,dremel batt slots,open up motor space so the motor stays cooler?ny info will be well appreciated!!
Steven ALexander
crACkeD ChaSsiS is offline   Reply With Quote
Old 10-16-2004, 07:00 PM   #2
Registered User
Have you tried searching? I've seen this topic posted several times before with a link, you could try that.
As far as doing it, I've done it several times and honestly having pictures or seeing someone else do it really doesn't help much. If you know how to use a dremel, have a good assortment of bits and know how to use them, it's pretty self explainitory.
Myself I just use a cutting wheel and high speed cutter to remove the material and cut the battery slots. You just cut half the center channel out, extend the slots towards the middle, and chamfer them. I oversize them a little to move the batteries down as well as in.
It would be a much cleaner job if one had access to a drill press.
Desolas is offline   Reply With Quote
Old 10-16-2004, 08:42 PM   #3
Default BUMP
Bump!!!help Plz
Old 10-16-2004, 09:16 PM   #4
Registered User
Did you search or just bump your post?
It took an entire 45 seconds to find this, by searching.
http://www.mistercrash.ca/_themes/page_mod_tc3.htm
Google is still useful if you can't find it in the forums.
Old 10-16-2004, 10:05 PM   #5
on that site they have to pics of his tc3 being weighed with 1 scale! how do you do that, because i have one scale like that and i dont want to by 3 more?
kh15 is offline   Reply With Quote
Old 10-17-2004, 03:43 AM   #6
Speedie's Avatar
I use one scale to do scale my car. Here are some pics. The trick is making sure both surfaces are even and level.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 10-17-2004, 03:44 AM   #7
Speedie's Avatar
Another
You can use paint sticks or any flat pieces for this. I made the lexan ones because I use them every week.
Hopped Up Nitro TC3s revzalot R/C Items: For Sale/Trade 11 04-09-2007 11:01 PM
2 tc3s 4 sale guilty503 R/C Items: For Sale/Trade 2 09-13-2006 11:50 AM
TWO TC3s Rollers!!! TRADES ONLY! nbcaznmaster R/C Items: For Sale/Trade 7 04-03-2006 05:56 PM
Extreme Chassis Website? tc3stocker Electric On-Road 10 01-30-2005 02:07 PM
Tv Shows nitrous36 Chat Lounge 73 11-16-2004 09:15 PM
