Old 07-03-2011, 07:30 AM   #1
elery's Avatar
Default TC5R problem
I bought this car used from a guy that use to use it as a drift car and i'm using it for onroad tc racing. My problem is everytime my car is going down the straight away and i go on the brakes, it is doing a full 180 degrees. Can someone tell me whats wrong and how i could fix this problem? If this is any help. i race in a car park and the traction is very low.
elery is offline   Reply With Quote
Old 07-03-2011, 07:50 AM   #2
wtcc's Avatar
What setup do you use? Did you check the car after you bought it?
With more information it is easier to analyze the problem, because there are a few things that can cause you spinning.
wtcc is offline   Reply With Quote
Old 07-03-2011, 08:40 AM   #3
black_knight's Avatar
That sounds like a oneway is in the front, or you front diff is way to loss.
Team Epic
Right Back Pocket Racing
AE all the Way who needs an Xray. LOL
black_knight is offline   Reply With Quote
Old 07-03-2011, 09:50 AM   #4
Foxxrocket's Avatar
I argee with what's said above. And I suggest you do a compete breakdown of the car, and make sure everything is there. Use the manual to help identify parts, then go back to the factory car setup.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 07-03-2011, 10:00 AM   #5
Buckaroo's Avatar
Also, the front may be sprung so soft that all the weight is transfering to the front. Having the rear droop set wrong will do the same thing.
Too many variables to go through until you list your entire set up! Having raced TC5s in two classes last year, I recommend going back to the kit set up (you can download the manual from AE's web page if you don't have it) and adjust from there.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 07-03-2011, 10:00 AM   #6
Strip down the car and start from scratch.
Rebuild the shocks. Try 40wt. in the front, with blue springs and 30wt. in the rear with green springs.
Set your ride heights at 6mm in the front and 5mm in the rear.
Check the caster and camber setting all around the chassis.
After you rebuild the car, check the weight balance, front to back and side to side. Most guys had to add a ton of weights to balance their cars.
These worked for me, but check through the tc5 thread and you will find plenty of info that should help.
Goals Achieved....Running at the End and Not Dead Last.
mooby64 is offline   Reply With Quote
Old 07-03-2011, 10:14 AM   #7
lochness42's Avatar
Most drifers I belive swap spool from front with diff in rear. Check that.
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 07-03-2011, 06:10 PM   #8
elery's Avatar
Default TC5R Problem
I will do that and see where it takes me. Thanks a million guys.
Old 07-04-2011, 03:13 AM   #9
Trader Rating: 15 (100%+)
+1
jay m is offline   Reply With Quote
Old 07-04-2011, 03:58 PM   #10
elery's Avatar
I have another question though. How do i find the 50/50 weight distribution around the car? What do i use or how do i know it has that kind of distribution?
Old 07-04-2011, 08:06 PM   #11
Ask around and find another racer that has a set of scales, 2 is good, 4 is better. Use the scales to check the balance of the chassis, front to back, and side to side, after you have all the electronics, motor and battery mounted. Weigh the car without the wheels or shocks, you are looking for a static balance of the car. Add weight, as low as possible to even out the car. After you have it close, you can put the shocks and wheels back on and tweak the weight this the shocks and springs. Hope this helps.
Team Associated Factory Team TC5R - like new with extras JColeman R/C Items: For Sale/Trade 22 12-29-2010 01:40 PM
TC5R/DX3R/2 Slashes and other parts FS 1995_corvette R/C Items: For Sale/Trade 30 07-24-2010 08:21 AM
TC5R torque steer? grvn Electric On-Road 25 11-05-2009 09:38 PM
Is the AE TC5R made in china or USA? s13evo Electric On-Road 34 04-24-2009 06:57 AM
