CEFX 12th Scale...No good >
Old 10-16-2004, 05:12 PM
  #16
Josh wont be very happy to see this, now will he?
Tony Szep is offline
Old 10-16-2004, 05:18 PM
  #17
ddesros2's Avatar
Edit
ddesros2 is offline
Old 10-16-2004, 05:25 PM
  #18
did you have foam on your bumper?
Old 10-16-2004, 05:44 PM
  #19
ddesros2's Avatar
Edit
ddesros2 is offline
Old 10-16-2004, 05:49 PM
  #20
ive seen cefx cars with decient size bumpers. i have 1 on mine.
any way i think i heard some thing about him coming out with a new bumper arms and neon green screw kits, i forgot about that.
Old 10-16-2004, 06:25 PM
  #21
ddesros2's Avatar
Edit
ddesros2 is offline
Old 10-16-2004, 06:28 PM
  #22
y dont u try it for one more race and see how it holds up
craziracer is offline
Old 10-16-2004, 06:45 PM
  #23
RobS's Avatar
Originally posted by Greg Anthony
is that in Windsor or Chatham?
This track is located in Kingsville.
RobS is offline
Old 10-16-2004, 07:03 PM
  #24
ddesros2's Avatar
Edit
ddesros2 is offline
Old 10-16-2004, 07:08 PM
  #25
berger's Avatar
No offence, but you seem like a bit of a short tempered numpty. Two heats with any car could cause stuff to break, hell you own a tc3, a little tap on the wrong section on one of those and you have three wheels. I say give the car a chance, pickup that spare and run at least a couple more meetings before you make a decision.
berger is offline
Old 10-16-2004, 07:27 PM
  #26
Each car out has some problems with it. The Associated front ends used on all of the other cars break too. My guess is that you caught a joint in the boards. Nothing will keep you from breaking if the wheel catches and stops.
Hope you got one of the newer IRS chassis...I broke 2 of them before giving up. Told me that there wasn't a problem with the chassis at Cleveland last year and then changed the chassis to fix the problem. Nice...
Unregistered is offline
Old 10-16-2004, 11:32 PM
  #27
A_Stratus's Avatar
I was marshalling the race and believe me, IT DIDN'T GO INTO THE WALL THAT HARD!
Dan is an awesome driver so I'm pretty sure he didn't really crank anything in practice to weaken it...
A_Stratus is offline
Old 10-17-2004, 05:22 AM
  #28
Chill Will's Avatar
If it's a problem I'm sure Josh will fix it. Wait till he gets back before you strip the car down. Losi had problems with thier some of their cars when it first came out and they fixed it( XX4 & XXX4 ) so i'm sure the proble will be fixed..
Chill Will is offline
Old 10-17-2004, 05:44 AM
  #29
Registered User
Maybe instead of coming on here and complaining like a Jack a$$ you should call CEFX and discuss the problem there. I know Josh will work with you to fix the problem.
One4u2nv is offline
Old 10-17-2004, 07:42 AM
  #30
KE4PJO's Avatar
You must have had a real bad time in the OLD AE days, bustin' front ends and T-Plates.
KE4PJO is offline
