Old 06-30-2011, 07:33 PM   #1
TWRC's Avatar
Questions?? Need Gearing Suggestions
I keep burning through gears like nothing and I need to find a better gearing setup for my TT-01. The CastleCreations setup keeps crushing spur gears (MY MESH IS PERFECT SO DONT EVEN GO THERE ). I was running a 61 spur and 19t pinion but I think I need a better setup. I have here a 19t and 18t pinion and a 55t and a 58t spur. I would like to buy the least amount of new gears so if you can think of a setup that incorporates one of these that would be great. Btw these are 48 pitch and I run touring
2.4.R
TWRC is offline   Reply With Quote
Old 06-30-2011, 07:54 PM   #2
RaceAce701's Avatar
Trader Rating: 86 (99%+)
what motor are you running
are you using the plastic motor mount
does the car have a top deck
it sounds to me like you are getting a fair amount of chassis flex which is affecting the gear mesh
those cars dont work well with much over a silver can in stock form they are flexy flyers
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 06-30-2011, 08:10 PM   #3
TWRC's Avatar
Post
Its a castle creations CM-36 4600kV. Yes, it is the plastic motor mount and yes, it has a top deck
The chassis flex would explain this:
2.4.R
Old 07-01-2011, 05:03 PM   #4
TWRC's Avatar
Post
Would a graphite fiber chassis keep it from flexing
2.4.R
Old 07-01-2011, 06:43 PM   #5
Suspended
Is it the chassis or the motor mount causing it? A powerful motor could cause the motor mount to flex or squirm about somewhat through a mix of tourque and heat, which would give un-even wear on the spur. I would start by eliminating that first, a alloy motor mount is going to be cheeper than a carbon chassis and something you would need to upgrade anyway even if you went carbon.
RogerDaShrubber is offline   Reply With Quote
Old 07-02-2011, 08:26 AM   #6
TWRC's Avatar
Post
Not sure. I'll probably try a $13 aluminum motor mount before I have to yet again disassemble the whole car to convert it to a $120 graphite chassis
2.4.R
Need ESC Suggestions for GTA class active_sport Electric On-Road 15 07-06-2009 06:41 AM
