shorter pinion set screws? >
Old 06-30-2011, 06:27 AM
poochy's Avatar
Default shorter pinion set screws?
Hello, where can i buy shorter pinion set screws than the one that comes with the pinion?
poochy is offline
Old 06-30-2011, 06:39 AM
Regional Moderator
CarbonJoe's Avatar
I just grind the set screws down with a Dremel. I use an old pinion to hold the set screw in place and grind away.
You can also try McMaster-Carr http://www.mcmaster.com/ They sell all kinds of fasteners in bulk.
CarbonJoe is offline
Old 06-30-2011, 08:13 AM
jjfo80's Avatar
dumb question..... But WHY??? Sorry intrigued ?
jjfo80 is offline
Old 06-30-2011, 09:27 AM
Chaz955i's Avatar
I just use a flat file to take a little off.
Chaz955i is offline
Old 06-30-2011, 09:51 AM
poochy's Avatar
thanks-will uses dremel or filer.
good question,,,,on the mi4cx-to get the motor as close to center line as possible-the pinion is flipped over so the pinion teeth number faces the lipo--the set screw is about 1mm too long--it slightly rubs the front belt causing slow wear and tear....
poochy is offline
Old 06-30-2011, 09:53 AM
jjfo80's Avatar
Ok cool thanks..... My tc6 and really any car I have had doesnt and hasnt had that problem
But thank you for explaining....
jjfo80 is offline
