Old 06-29-2011, 06:26 AM   #1
Default TT01 carbon reinforced gearset
Seems like all new TT01E kit releases are now coming with a carbon reinforced gearset as standard....... Will deffinately help when running a BL setup!
Can't find a link as yet but they are in the kits!
mr lee is offline   Reply With Quote
Old 06-29-2011, 09:16 AM   #2
....actually it is the whole set so the 61T spur and ring that holds the pin in on the spur is also carbon reinforced!
This is really cool and now means that you don't have to get the racing gear set right away....unless you are racing or need the ratio for a particular motor setup. Sadly the pinion gear is still the crappy soft aluminium so will not last long.
Still this is an improvement over the older set and big up to Tamiya for making this change....will surely keep customers coming back
