Which would you use??? >
Old 10-14-2004, 11:52 AM
vtl1180ny's Avatar
Default Which would you use???
Ok Let's say a motor has an effieciency around 81%, puts out 162 watts peak and spins 30k Rpm with brush/spring setup #1... Same motor with Brush spring setup #2 puts out 168 watts, 78% efficency and spins 31k Rpm....
Torque is almost dead even between the 2....
spring set #1 is softer than # 2...
vtl1180ny is offline
Old 10-14-2004, 11:55 AM
Jack Smash's Avatar
Trader Rating: 33 (100%+)
I would go with #2. It sounds like the springs might be too light on the first one and the brushes are bouncing when the RPM's come up.
Jack Smash is offline
Old 10-14-2004, 12:28 PM
fatdoggy's Avatar
No. 2 - More watt's, more rpm.
fatdoggy is offline
Old 10-14-2004, 12:43 PM
vtl1180ny's Avatar
Very tight track... This is a track we've always run stock only and now we're going 19 turn....
Old 10-14-2004, 05:21 PM
EddieO's Avatar
Power is power....as long as the one springs don't cause a fade of the motor because of excessive arching, then always take the most powerful motor....assuming this is a 19t...as efficiency is really not that big of a deal. Now, if efficiency matters, then the question also becomes, will this motor make runtime.
Later EddieO
EddieO is offline
Old 10-14-2004, 07:35 PM
for most classes of racing nowadays, efficiency is no problem, as eddie mentioned. Thankfully battery technology has evolved to the point where 5 minute races are achieved easily even with the hottest motors (except maybe mod tc on a really hot day). Stock, 19 turn, without a question go for the higher watts.
071crazy is offline
