shaft drive idea >
shaft drive idea
shaft drive idea
Old 06-26-2011, 02:50 PM
Default shaft drive idea
if i put a slipper clutch in my shaft car will i still get torq stear.I was looking at thunder tigers Sparrowhawk XB it has a onroad chassis.
bosco72 is offline
Old 06-26-2011, 03:28 PM
JimmyMac's Avatar
You could for bashing. But if you race, it is illegal to use slipper clutches in Touring cars.
JimmyMac is offline
Old 06-26-2011, 03:45 PM
i guss for bashing then... will it help stop the torq. stear.If it will they should alow it to race
bosco72 is offline
Old 06-26-2011, 08:35 PM
Torque steer is a myth designed to get everybody to switch from shaft drive to belt drive!!! All the cars I own are shaft drive, and I have never noticed such a problem ! It is all about the bottom line ! A slipper clutch is not necessary, and will only add rotational mass.....
bertrandsv87 is offline
Old 06-26-2011, 10:49 PM
If you understand what causes torque steer you would see how belt or shaft would not affect it. Torque steer comes from having one axle being shorter than another, common on FWD cars with transverse engine/gearbox combos. The torque steer type effect of RC cars is usually due to the play in the suspension from ball links etc. My brothers HPI srpint 2 has a lot of it for some reason, but you can tell it is a geometry reason and not much to do with it being belt drive.
kb525 is offline
Old 06-27-2011, 02:07 AM
daleburr's Avatar
Wow, some awesome nonsense in this thread...
Torque steer exists in all shaft drive cars because of Newtons third law. With the armature mounted along the chassis, when you spin the armature, the chassis will rotate in the opposite direction to the armature, with equal momentum to that of the armature. Some of this will be counteracted by the propshaft assembly since this also rotates in the opposite direction to the armature. If you look at Associateds land speed record car, you'll see a flywheel on the propshaft to totally counteract the armature torque and give a neutral car.
With heavy, large diameter brushed armatures and powerful motors (i.e. lots of momentum in the armature) this was a total nightmare and made the cars difficult to drive, hence the death of shaft drive cars as motors got faster and faster.
With small diameter, lighter brushless armatures (rotors), especially in spec classes with low motor power, this torque steer effect is much less noticable. My girlfriend runs a 17.5 blinky shaft drive and I can't feel any torque steer effect. It definitely still exists as you can't ignore the laws of physics, but it isn't big enough to cause any problems.
The torque steer on FWDs due to unequal driveshafts is something totally different and not relevant to RC due to our cars being designed properly.
daleburr is offline
Old 06-27-2011, 11:55 AM
well, please explain then how my brothers 15t sprint 2 belt drive has torque steer. what you talk about is the torque from the motor creating a force usually towards the dirrection of the spin, this pushes one side of the suspension down.
kb525 is offline
Old 06-27-2011, 06:08 PM
MattFromSooke's Avatar
Originally Posted by kb525 View Post
well, please explain then how my brothers 15t sprint 2 belt drive has torque steer. what you talk about is the torque from the motor creating a force usually towards the direction of the spin, this pushes one side of the suspension down.
chassis is tweaked. putting un-equal weight on the tires left to right and its causing it to pull when on throttle, check your left/right weight balance, and for equal shock length, spring length, and ride height, just make sure everything on the car is equal left/ right
MattFromSooke is offline
Old 06-29-2011, 10:04 AM
no no no. When you pick the car off the ground and floor it you can see the front steer to the right for a split second and center again. This isnt a balance issue.
kb525 is offline
Old 06-29-2011, 10:39 AM
academygaz's Avatar
That will be a faulty servo, a bent driveshaft, a weak differential spring, thin diff grease, a binding bearing etc. All through poor maintenance.
academygaz is offline
Old 06-29-2011, 11:30 AM
The car did it since brand new. Its not noticeble while driving unless on super slipery tires. All bearing have been oiled, car is belt driven so there wont be a bent shaft, has stock diff grease and diffs havent been opened (gear diff) and servo is ok. It is faulty suspension design if ive ever seen it. Probably from the inertia of the wheels accelerating acting on the suspension, though gyroscopic precesion takes far too long for it to be that.
kb525 is offline
Old 06-29-2011, 11:45 AM
IndyRC_Racer's Avatar
In response to the original post, there is a way to put a slipper on a shaft drive car. A company call RC Product Designs has an offroad conversion for the TC3. The offer a slipper assembly for that car. For more information, check out their website (http://www.rcproductdesigns.com/)
IndyRC_Racer is offline
Old 06-29-2011, 06:19 PM
That's a glitching servo issue. Unplug the servo from the receiver and the wheels shouldn't steer to the right when you blip the throttle.
The 'torque steer' effect can be seen on a belt drive car, pick it up and hold it in the air halfway along the chassis. When you blip the throttle the front end will lift and the rear end will drop. This torque effect on the chassis on a belt drive car helps push the rear wheels down under acceleration for more grip to put the power down. But with the motor in a shaft drive chassis this same motor torque will lift one side of the chassis while pushing down on the other, causing it to steer one way under acceleration and steer the other way when braking. As Daleburr pointed out, with the lighter armatures in brushless motors today the effect isn't as noticeable as it used to be.
terry.sc is offline
Old 06-29-2011, 07:01 PM
Again torque steer effect is a myth!!! I have run a 4t brushed motor in my tc4 , and I don't notice it guys!!! I also don't balance my car, and don't use a setup station!!! When I hold my tc4 and accelerate, the chassis moves front to back, and not side to side!!! The effect is either too small or inexistent!!!! Shaft cars are still alive, even if some people believe in the brainwashing myth of torque steer....Besides, if it were such a problem, all the fullsize race cars would have switched to belt drives by now...LEARN THAT!!!!!!!!
Old 06-29-2011, 11:07 PM
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Run and tell THAT, HOMEBOY! lol
Y'all crack me up!
andrewdoherty is offline
