Old 10-14-2011, 11:16 AM   #16
Harry, I will get back with you about the acetone as soon as I can get the information. Thank you for the conversation it will help me learn about the needs of RC racers and help provide them with the best possible product and service we can. Im glad you know some karting guys running our prep and they are happy. Word of mouth and a good reputaion are the best business practices in my book. We strive to support all racers and ensure they are 100% happy with any of our products. I would still love to do some testing if anyone has some old tires they would want to send. Given the information you have given me and the ability to test our prep on the tire we could find the best match to help the racers. Harry I will get back with you as soon as I get the information and thank you for the information from your end.
http://ftstireprep.com/
csteel14golf is offline   Reply With Quote
Old 10-14-2011, 11:45 AM   #17
With all these tire preps, which would be best for foam tires, 12th and 10th scale?
RoyU is offline   Reply With Quote
Old 10-14-2011, 11:49 AM   #18
HarryLeach's Avatar
Send a message via AIM to HarryLeach
RoyU, a more oil based prep is usually best on foams, quite a few solvent based preps can destroy foams.
I look forward to your answer. If you're looking to do some testing, it would probably be bst to send samples to someone for feedback.
On that side of things, I have a durometer, race TC and 1/12, and have access to an asphalt track and an "open sauce" carpet track, if you're interested.
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 10-14-2011, 04:04 PM   #19
Harry, the mentioned preps earlier EL Elite, Black Bite, TT1, and HT1 do not have the xylene or acetone. Are you a dealer for another prep?
Old 10-14-2011, 05:39 PM   #20
HarryLeach's Avatar
Nope, no dealer, I've made preps for my own use in the past, but now only use prefab products on my own nickel for all my racing, due to time constraints of work.
If you want some rc specific testing and feedback, I would be willing to work something out.
Old 10-16-2011, 10:31 AM   #21
Look forward to getting some test in.
Old 10-16-2011, 12:56 PM   #22
HarryLeach's Avatar
Sounds good, replied to PM.
Old 10-24-2011, 09:06 AM   #23
Harry, I tried to call to let you know the samples were on the way. You should have gotten them by now. If you want call me and I can explain what they do.
Old 10-24-2011, 12:59 PM   #24
HarryLeach's Avatar
My wife tells me they showed up today, YGPM.
Old 01-31-2012, 09:46 AM   #25
HarryLeach's Avatar
After 3 back-to-back weeks of testing on carpet, I'm ready to give everyone a run-down on the preps I've tried.
On our Carpet, the normal prep is black can Paragon, and there's been some issues when people run other sauces. FXT seems to be the prep people are migrating to, but the FXT guys struggle with grip and tire build up when there's quite a few guys running Paragon, so I was very careful to listen for any complaints about track inconsistency on race day, and watched the cars closely each run to make sure the track was consistent enough to gather usable feedback. The biggest shower was 1/12, where I found my car consistent each run, so I feel confident in saying there wasn't any weird reactions with the track and existing preps in use.
On Rubber Tire TC:
HT Series 1:So far, the sauce I've used the most has been the Clear [colors are a bit easier to reference] HT Series 1. This sauce removed tire build up faster than anything else I've tried, and left the tire feeling very fresh. Previous cleaners I've tried were lacquer thinner, motor spray, lighter fluid, denatured alcohol and Simple Green, and this stuff cleans the tires better than anything else. After a run, douse the tires, rub clean with a clean rag, inspect your tires, then apply more. This stuff dries slow, in the neighborhood of 15-20 minutes, but I've found no difference in grip letting it dry on the tire, or wiping the tire off while still wet.
On the track, the tires scrubbed in quickly, and were consistent the entire run. Tire temperatures were on par with guys running other sauces.
Slight Bite: Red. This sauce dries very quickly, but has a strong chemical smell. Using the Clear to clean, and saucing with the Red, the tire had more grip early in the run, but had more fall-off at the end of the run, which made the car a bit harder to drive. This problem is more pronounced running lots of warm-up laps before starting a qualifier or main. Tire temperatures at the end of a run were also lower, so I may revisit this compound when asphalt season starts up again.
Black Bite: Black. Again, cleaning with Clear, sauce with Black. This sauce has a medium drying time around 10 minutes. I found that this compound made the car pretty free mid-corner, not tail sliding, but definitely not digging into the track. The biggest problem I had is that the tires never seemed to give full confidence until around the 4 minute mark, which is way too long to wait in a 6 minute race. Tire temps were even lower than the Red, so I will definitely revisit this sauce on asphalt.
In all, I pretty much just cleaned and sauced with the clear, and had a nicely consistent car.
Foam Tires, 1/12:
TT Series: Green. This is used in karting as an "inside the tire" prep, applied through the valve stem. I really liked the way it made foam tires feel in my bench testing, so it's been the sauce I've tested the most so far. As long as the tires feel moist when you put the car on the track [not sopping wet, but not as dry as untreated], this sauce is AWESOME. In practice testing, this sauce doesn't fall off for 20 minutes or so, and scrub in before starting a heat only takes 2 laps. The consistency of this sauce makes it loads easier to diagnose tire compound and handling issues. Due to the track build-up on our older carpet, I started cleaning my tires with motor spray between rounds, and keeping them sauced wet as long as possible to maintain consistency between rounds. Without cleaning, a set of tires will gradually grip the track harder and harder throughout the day, killing corner speed.
Sauces still to try:
Due to not having enough sauce bottles to try all the varieties csteel sent me, I haven't had a chance to do anything more than bench testing on these remaining sauces, so I've included my impressions from bench testing on older tires.
E.L. Elite Orange. Dries Fast, around 5 minutes, has a mild parts cleaner smell, and dries without making the tire feel oily, or tacky, just dry. I'll give it a try when I have a chance, but not holding real high hopes for this sauce on carpet.
HT Series 2 Light Blue. Slow drying, strong chemical smell. Seems to leave the tire feeling similar to the Clear. The literature claims this is more aggressive than the Clear, so when I have a chance, I'll give it a shot on Carpet.
None of the Sauces I've listed have had any de-gluing of tires, no discoloration of the rubber, and generally nothing weird to report.
Disclaimer:
I'm not being paid to test these sauces, I was only supplied with samples of the compounds I listed and told "let me know what you think."
Old 01-31-2012, 03:09 PM   #26
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Harry, If you are inclined to do so I can send you some of our "sauces" for testing. We have been developing ours for about a year now and have had real good success.
Our products can be found here: TS tire sauces
PM Me or contact me at [email protected]
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 01-31-2012, 05:53 PM   #27
HarryLeach's Avatar
You've got mail.
Old 02-29-2012, 06:58 PM   #28
Harry,
Im sorry I have been extremely busy lately. Thank you for the testing and have you got to test the other products yet? We launched a new prep since your testing so if you want I can get you a sample of the new prep. That and we have about 5 more preps that I didnt send if you want to try them. I was glad to hear the testing produced faster lap times on 2 race old tires than it did on new sticker tires. I would still like to explore this market if this is somthing that would be beneficial to you guys. Thank you.
Old 02-29-2012, 09:06 PM   #29
HarryLeach's Avatar
Harry,
I'll test any preps you want to send.
Unfortunately, we've steam cleaned the carpet track and gone to odorless tire prep, so I'll have to get a ruling on whether the preps I've tried will still be allowed before running them any more.
BUT, asphalt season is coming quick, so there's plenty of testing time upcoming.
Old 03-01-2012, 03:08 AM   #30
Skiddins's Avatar
I'll be interested to see what your testing shows outside on asphalt.
Also, will you be trying the 'Tire Wash'? I'm assuming it's a cleaner for after the run?
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
T.R.C.R. ---Pit's Talk--- teambighead Northwest Racers 25141 12-03-2017 10:06 AM
R/C Stuff Wanted Kenneth Tan Singapore R/C Racers 10018 09-09-2009 08:32 AM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
Vintage R/C tires... all NIP, old & odd treads and sizes... drew840 R/C Items: For Sale/Trade 9 10-02-2006 02:35 PM
