Bodyshell mounting, height ? >
Old 06-24-2011, 08:31 AM
Default Bodyshell mounting, height ?
Hi,
Just wondered whats the best way to get the body the correct height,
eg. do you mount it so the side edge of the shell is level with the chassis or do you just adjust it once the wheels are fitted and adjust it so it doesn't hit when the car is pushed down, if you get what I mean
S.A.W is offline
Old 06-24-2011, 08:58 AM
daleburr's Avatar
Originally Posted by S.A.W View Post
Hi,
For best performance (low CoG and least drag) the roof height should be adjusted to be just over 120mm from the ground, with the car on a 10mm block, which is as low as the BRCA rules allow you to go.
You then trim the shell so that it doesn't catch on the floor. You can get pretty close by pitching and rolling the car on the workbench, although I always end up trimming a touch more off at the track, but it's best to start on the safe side and not cut more off than necessary.
daleburr is offline
Old 06-24-2011, 09:05 AM
Thanks.
S.A.W is offline
