duo 3 13.5 in a Pan car >
Old 06-24-2011, 01:57 AM
Default duo 3 13.5 in a Pan car
Need rollout for a duo 3 13.5 in a 1/12th and WGT pan car.Boosted and non boosted.
Also what about can timing and guidance on that would be great.
tellan is offline
Old 06-25-2011, 06:47 PM
bkspeedo's Avatar
13.5 12th scale timing;
Try a roll-out around 2.3 - 2.6, no timing or very little in the motor, most from the ESC.
13.5 WGT timing;
Try a roll-out around 2.2 - 2.5, no timing or very little in the motor, most from the ESC.
13.5 WGT no-timing;
Try a roll-out around 3.0 - 3.4, Full to almost full timing in the motor.
Of course this depends on track size and layout flow. Go up on roll-out for a large flowing track, and down for small tight track. These are starting points, your driving style may require a different range. Always temp motor at 3min when making gearing and ESC timing changes so you don't burn-up your motor.
bkspeedo is offline
