Old 05-16-2002, 02:38 PM   #1
B3boy's Avatar
Send a message via AIM to B3boy
Default Micro RS4 Servo Trouble
I just got a new Micro RS4. I was runing it around in the house and sometimes when i crash it into the walls, the servo unsticks from the tape. I don't know if it is just bad servo tape or what, but It keeps hapening. I was sure to get both surfaces very clean (I used cleaner and didn't touch it). Is there a way to fasten the servo on better?
I also wanted to know how long it would run with four AA bateries. I have read things that range from 15 to an hour.
Thanks,
Jake
B3boy is offline   Reply With Quote
Old 05-17-2002, 04:18 AM   #2
RC Nitro's Avatar
Jake
Try different servo tape. Mine sticks no problem and it has hit numerous items in the house. The car is my 6 year olds She like getting it stuck under the kitchen island. Daddy helps too Cuts great donuts on tile floors. I get between 20 - 25 min on duarcells. Have not tried a NiMh pack yet or rechargable batteries.
RC Nitro is offline   Reply With Quote
Old 05-17-2002, 03:43 PM   #3
B3boy's Avatar
Yeah, I guess I will just go out and get a good quality roll of servo tape. Thanks for the help
Old 05-17-2002, 05:18 PM   #4
newracer's Avatar
R/C Tech Charter Subscriber
shoe goo works great, that's what I use
newracer is offline   Reply With Quote
Old 05-19-2002, 07:54 AM   #5
Flash Gordan's Avatar
Send a message via AIM to Flash Gordan Send a message via Yahoo to Flash Gordan
I used bolink servo tape and my servo hasn't come loose yet. Anybody know when the micro's first hit the market? Cause that's when I got mine. It was the first one around here.
Flash Gordan is offline   Reply With Quote
Old 05-19-2002, 08:18 AM   #6
Try taking a scotch brite pad or brillo pad and scuff both the servo case and chassis, then use 1 pice of tape on the bottom and 2 on top (one on top of the other), trust me the servo will stay put.
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 05-19-2002, 09:47 AM   #7
fIShCaKe's Avatar
Send a message via MSN to fIShCaKe Send a message via Skype™ to fIShCaKe
Hey, try using 3M Heavy Duty tapes on the main chassis and the top deck, it should secure the servo properly..
The run time of the car actually depends on the motor ya are using, the capacity of the cells and the style ya drive ya car. Some people may be able to get the car to last for an hour provided that they use 1600mAH rechargable cells!
fIShCaKe is offline   Reply With Quote
Old 05-19-2002, 05:32 PM   #8
B3boy's Avatar
Cool
Hey, thanks a lot for the help. I will be sure to try your ideas.
I have another question though. I have an original Super Brain charger. I want to get rechargable bateries for my Micro and a receiver pack for my nitro. Is my charger capable of charging these? Also, would I need to buy any attactchments?
Old 05-20-2002, 05:04 AM   #9
RC Nitro's Avatar
Jake
I do not know the spec's on your charger, so I am shooting from the hip here. I had an old Tekin BC112c, but it puked 6 months ago. That did well for both receiver and batt's.
I have not broached the rechargable packs yet for the micro, but I think they are in the same catagory as receiver packs. Your super brain charger should work fine. Sould be able to do a 1C charge without a hitch. I charge my receiver packs at 1 amp for both the 1000's and the 1100.
However, if you want to get a bit anal and install the "C" size 3000's then you will need a better charger. )See the latest R/C Car for that article.) I been talking with Ron @ Pro Match and Danny of SMC on batteries. You will need a high peak detection for the sanyo cells than the std fixed rate of most chargers.
Old 05-20-2002, 08:57 AM   #10
B3BOY- No the Superbrain will not charge anything other than sub-c cells, now if you get the new superbrain it will,
Old 05-22-2002, 05:44 PM   #11
B3boy's Avatar
what Charger?
I didn't really think my Super Brain would work. I was thinking about getting the DuraTrax IntelliPeak. It is cheap and charges both types of bateries. Do you guys have any suggestions on a good charger that is not more than $75. I want to get rechargeble bateries for my micro, alkalines just wear down too fast.
Old 05-23-2002, 04:19 AM   #12
RC Nitro's Avatar
Jake
I was in the LHS yesterday and talking to "the man". What he has done on his micro is a LRP reversable esc and uses nitro reciever packs. These are bigger than the micro packs Orion sells and you can use 540 motors on the car! I am going to go this route as my daughter smoked the esc and LRP are guaranteed for life. Plus the reciever pack gives ~ 45 min runtime.
Old 05-23-2002, 04:02 PM   #13
B3boy's Avatar
That sounds cool, I bet it would fly with a 540 motor on it. Wouldn't you need to buy a conversion kit or something to get it to fit?
Old 05-28-2002, 05:03 AM   #14
RC Nitro's Avatar
Check out this months (July 2002) R/C car mag for the article on the micro with a quatum reverse, 540 motor and 6 cell pack! I am at work so I do not have the article.
Hitec/airtronics servo trouble with FASST wstuart Nitro Off-Road 7 08-08-2008 03:01 PM
FS: Xray M18 Kit + Micro Servo Saver, Servo and Receiver paulsrc R/C Items: For Sale/Trade 7 12-20-2007 07:38 PM
Servo Horn trouble Ridge_Racer Rookie Zone 3 06-02-2005 11:30 AM
