3x6 Black Aluminum Spacers >
Old 06-18-2011, 05:51 PM
Robertcooper88's Avatar
Trader Rating: 15 (100%+)
Default 3x6 Black Aluminum Spacers
I know this is a dumb question but I am having alot of trouble finding 3x6 aluminum spacers. I know TOP makes some. Can anyone point in the right direction?
Thank you
Robertcooper88 is offline
Old 06-18-2011, 05:55 PM
jjfo80's Avatar
we need more info mate..... 3x6mm spacers doesnt help...
Internal dia plus external dia plus thickness..... makes it easier to understand
What are they used for ???
jjfo80 is offline
Old 06-18-2011, 06:00 PM
Spacers used for Roll Center Adjustments, wheelbase adjustments etc. I did not give the last dimension because I need .5MM all the way to 3MM
Old 06-18-2011, 06:26 PM
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
XRA303122-K 3x6x1mm black
XRA303123-K 3x6x2mm black
not sure about a .5 offhand
-rocky b
flatspunout is offline
Old 06-18-2011, 06:49 PM
Viper2011's Avatar
Default hi there
Hi there ,First of all,what are you trying too do? Widening the wheel length? <--->,If you are? Don`t bother going down too you`r hobby store and buying the over priced spaces!,Just use the normal Hexi wheel spacer you have,With some metal washers on top of the Hexi spacer,Get em from your hardware store! Dos the same thing..And dos not damage the wheel or the Hexi wheel spacer,And you can add more or less too adjust too how you like it.
Viper2011 is offline
Old 06-18-2011, 07:26 PM
Trader Rating: 32 (100%+)
If you don't mind a little blue, these will get the job done at a much better price than most anything out there...
http://www.speedtechrc.com/store/ebp...id=961&id=1729
They are 3x5.5, but they should still work.
ittjv is offline
Old 06-19-2011, 03:30 AM
Viper2011's Avatar
It`s an over priced washer!,I`m sure you would be better looking in you`r "shed" before forking out cash on some painted washers!! :P,After all,You don`t see the color when there on now don`t we.. LOL:
Old 06-19-2011, 05:58 AM
Potoczak's Avatar
Trader Rating: 120 (100%+)
3 racing makes almost any size and color you need
Potoczak is offline
Old 06-19-2011, 06:55 AM
Regional Moderator
CarbonJoe's Avatar
http://www.nexusracing.com/index.php?cPath=148_208_117
CarbonJoe is offline
Old 06-20-2011, 02:55 PM
The Big Wig's Avatar
Takeoff: 0.5x3x6
Square: 0.5x3x5.5
Eagle Model: 0.5x3x5
The Big Wig is offline
