Old 06-17-2011, 04:34 AM   #1
Default RC grease from auto shops??
After continually running out of RC grease, the tubes are tiny....
What grease from auto shops is usable ??
It will be cheaper & big auto size tins & tubes
1101 is offline   Reply With Quote
Old 06-17-2011, 05:05 AM   #2
Molybdenum or lithium grease from auto parts is good for thrust bearings, gear transmissions, universal axles, and so on
Fastfreddy74 is offline   Reply With Quote
Old 06-17-2011, 05:23 AM   #3
AM03GT's Avatar
Swaybar bushing lube/grease works great for CV's and dogbone joints.
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 06-17-2011, 11:22 AM   #4
You need to be careful of automotive greases, oil based is not good for plastic or rubber, I ve been using superlube for years, it's synthetic and plastice safe,if you need thicker? try silicone brake grease,thinner then super lube? try synthetic brake caliper grease
Joat is offline   Reply With Quote
Old 06-17-2011, 03:11 PM   #5
YR4Dude's Avatar
Trader Rating: 44 (100%+)
You can also get lithium and moly grease at the bike shop. They may be safer to use on RC than automotive lubes.
YR4Dude is offline   Reply With Quote
Old 06-17-2011, 04:05 PM   #6
Straight Castrol High Temp Bearing Grease (dont overpack the bearings)
usage Bearings,Diff,CVs just not to much.
Robitronic Avid / Avid V2
Tekin RS pro / Viper 10.5/MMP/6900
AE B44- MMP/Hacker 10.5/6900 Castle
IP 5000/50 SMC 5200/40/50
Casino Kid is offline   Reply With Quote
Old 06-17-2011, 04:09 PM   #7
JayL's Avatar
exactly what grease are you talking about? you won't use the same grease in the diff thrust and you would in bearings.....
JayL is offline   Reply With Quote
Old 06-17-2011, 05:05 PM   #8
All RC grease in general. Ball Diff grease is probhably the only one I would still use the RC stuff.
Old 06-17-2011, 06:00 PM   #9
JayL's Avatar
mobil 1 synthetic grease
Old 06-19-2011, 11:58 PM   #10
Im having trouble finding this anywhere locally. Is it still made ??
Old 06-20-2011, 07:33 AM   #11
wingracer's Avatar
Trader Rating: 24 (100%+)
Yes it is.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 06-21-2011, 09:37 AM   #12
Trader Rating: 48 (93%+)
lucas oil red n tacky in bearings,trannys,have used it in diffs, 4.95 for a huge tube.. had the same tube for a year and still have loads left.. when racing baja 5b i got a thing of team fast eddy lube opened it up to find out they where charging 13bucks for a tinny thing of lucas oil red n tacky. i knew that from working on a race team that was sponsored by lucas oil..
tcb22185 is offline   Reply With Quote
Old 06-21-2011, 02:45 PM   #13
Akhor's Avatar
What about "Green Slime"? Where can you find that in a large container?
--Blaine--
VBC D07, VBC D08
www.carcar.ca
Akhor is offline   Reply With Quote
Old 06-21-2011, 03:49 PM   #14
Trader Rating: 14 (100%+)
http://shop.noleenj6.com/product.sc?...8&categoryId=2
thunderbt3 is offline   Reply With Quote
Old 06-21-2011, 05:53 PM   #15
koopesv's Avatar
Trader Rating: 18 (95%+)
+1 on this, I just used it today. works awsome and you get so much for like 8 dollars you can give away a lot and it will still last years.
Durango - Speed Passion - Trinity
Gforce Hobbies Raceway
Urban Heat Racing
koopesv is offline   Reply With Quote
Grease? koopesv Nitro Off-Road 20 01-25-2011 08:53 PM
